- To:
- Subject: Re: [cgal-discuss] CGAL and PDB
- Date: Thu, 28 Jan 2010 13:39:17 +0100
On Thursday 28 January 2010 12:25:19 Samuel Hornus wrote:
> Greetings,
> The CGAL distribution (3.5.1) contains a lot of code (headers and a
> libCGAL_PDB) for reading and inspecting PDB files. Yet, it seems that
> no documentation is available (on CGAL's website), or did I miss
> it?
> - Is it useless code that should be removed from the library at some
> point in the future?
> - Or is it code that will stay in CGAL (that I can count on being
> maintained) and which should be documented?
That piece of code, like libCGAL_ImageIO, is only used internally and is not
documented. It will not be documented in the future, and may be replaced by
another way of reading PDB files.
If you are looking for a PDB reading library, that is maintained, you could
try:
http://esbtl.sourceforge.net/
Laurent Rineau, PhD
- [cgal-discuss] CGAL and PDB, Samuel Hornus, 01/28/2010
- Re: [cgal-discuss] CGAL and PDB, Timo Strunk, 01/28/2010
- Re: [cgal-discuss] CGAL and PDB, Laurent Rineau (GeometryFactory), 01/28/2010
- Re: [cgal-discuss] CGAL and PDB, Nico Kruithof, 01/28/2010
- Re: [cgal-discuss] CGAL and PDB, Samuel Hornus, 01/28/2010
- Re: [cgal-discuss] CGAL and PDB, Daniel Russel, 01/28/2010
