- To:
- Subject: Re: [cgal-discuss] Triangulate polygon with holes
- Date: Thu, 11 Feb 2010 14:49:32 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=Sp+4KTLt7bMqnsmm1FD2ZFKmg1VmS4tFjCghhwrUqbFUiYuhqG7yHoIvkuiFo9mqBl nEHN+Lfa1WrFVPqZO4iCYH9jV90wCUetJQCuw2ns+hOuZEy31uM9Klz/At25gwbH7rAl jnD7pph+QOa0wvO+bCV2DxSfjrzY54wd6Ii0Y=
You can ask if an edge is a constrained or not. The class you are using for example provides you with such a function.
As for the tagging, you can use Face_base_with_info class to add attributes to your faces, say, the variable "bool IsOutside", or a whole class... There is another way, useful only when your new attributes depends on the Face_handle type.
On Wed, Feb 10, 2010 at 2:53 PM, Agnel C J Kurian <> wrote:
I am using Constrained_triangulation_2 to triangulate a polygon with holes in
it. I am adding the external boundary and the boundary of the holes as
constraints.
How do I then exclude the faces/edges which fall within the holes?
A solution was suggested here:
http://stackoverflow.com/questions/406301/406647#406647 (However, I have not
been able to act on it till now.)
"You can then tag the triangles of the triangulation by any traversal
algorithm: start with a triangle incident to the infinite vertex and tag it as
being outside, and each time you cross a constraint, switch to the opposite tag
(inside if you were previously tagging the triangles as outsider, outside if
you were tagging triangles as insider before)."
How do I check when I cross a constraint? How do I tag a triangle?
- [cgal-discuss] Triangulate polygon with holes, Agnel C J Kurian, 02/10/2010
- Re: [cgal-discuss] Triangulate polygon with holes, Panagiotis Foteinos, 02/11/2010
- Re: Re: [cgal-discuss] Triangulate polygon with holes, Agnel C J Kurian, 02/12/2010
- Re: Re: [cgal-discuss] Triangulate polygon with holes, Panagiotis Foteinos, 02/12/2010
