- To: CGAL Mailinglist <>
- Subject: [cgal-discuss] Converting quantities with different kernels
- Date: Tue, 16 Feb 2010 16:12:56 +0100 (CET)
- Organization: Institut fuer Werkstoffe TU Braunschweig
Dear all,
in my last question I asked about Nef_polyhedra. by now I found out
that my problem was due to having an extended kernel.
So here is the next (hopefully more simple) question: Can I convert
geometric quantities in an easy way between different kernels?
I have:
typedef CGAL::Homogeneous<CGAL::Gmpz> Kernel;
typedef CGAL::Extended_homogeneous<CGAL::Gmpz> EKernel;
typedef Kernel::Plane_3 Plane_3;
typedef Kernel::Point_3 Point;
typedef Kernel::Vector_3 Vector_3;
typedef EKernel::Plane_3 EPlane_3;
typedef EKernel::Point_3 EPoint;
typedef EKernel::Vector_3 EVector_3;
Is there a simple way to convert a Plane_3 into a EPlane_3 (and the
same with vectors and points) and vice versa?
Thanks for any help,
Martin.
Priv.-Doz. Dr. Martin Bäker
Institut für Werkstoffe
Technische Universität Braunschweig
Langer Kamp 8
38106 Braunschweig
Germany
Tel.: 00-49-531-391-3073
Fax 00-49-531-391-3058
- [cgal-discuss] Converting quantities with different kernels, Martin Baeker, 02/16/2010
- Re: [cgal-discuss] Converting quantities with different kernels, Sebastien Loriot (GeometryFactory), 02/16/2010
- Re: [cgal-discuss] Converting quantities with different kernels, Martin Baeker, 02/17/2010
