- To:
- Subject: Re: [cgal-discuss] using a C Polyhedron instead of C++
- Date: Sat, 20 Feb 2010 11:10:18 -0500
I think you're probably better off simply using the data structures as they are and creating a bunch of extern functions to
update and query the data structures as you need to. You can handle C++ objects in C as either void pointers or PIMPLs.
--Mike
Mohamed Yousef wrote:
Hello all,
how can i replace all data containers in the Polyhedron class to be in C not C++, without affecting the interface
and existing functionality (what templates required,how to specialize them) ?
i need this to access Polyhedron data from C (points , faces , edges , their relations )
Thanks,
Mohamed Yousef
- [cgal-discuss] using a C Polyhedron instead of C++, Mohamed Yousef, 02/20/2010
- Re: [cgal-discuss] using a C Polyhedron instead of C++, Michael George, 02/20/2010
- Re: [cgal-discuss] using a C Polyhedron instead of C++, Mohamed Yousef, 02/20/2010
