cgal-discuss - Re: [cgal-discuss] Custom Distance Metrics in Voronoi Diagram
  • To:
  • Subject: Re: [cgal-discuss] Custom Distance Metrics in Voronoi Diagram
  • Date: Mon, 22 Feb 2010 14:34:25 +0100
Laurent Rineau (GeometryFactory) wrote:
On Thursday 18 February 2010 06:18:01
wrote:
Hi,
I did not find any way to set a Distance Metric for my Voronoi Diagram. The
Euclidean metric is not what I want. Is there a way to feed or set a
desired distance metric in Voronoi Diagrams?
Hi
In fact you have some (limited) freedom about this.
I guess you are plugging the CGAL::Delaunay_triangulation_2 as Delaunay graph.
Then you can modify the in-circle test used in the Delaunay triangulation though the traits class (look at the documentation of the 2D Delaunay triangulation, in particular the concept DelaunayTriangulationTraits_2). This predicate can modify the shape of a ball, thus the metric used.
Of course you cannot put any arbitrary function there, or the algorithms will fail... For instance the metric must really satisfy the properties of a metric.
No. Voronoi diagram package is able to compute only euclidean distance Voronoï diagram.
If your distance is simply additive, then that is the Apollonius diagram:
http://upcoming.cgal.org/Manual/last/doc_html/cgal_manual/Apollonius_graph_2/Chapter_main.html
Otherwise, as far as I know, there is nothing in CGAL that computes Voronoi diagrams of arbitrary functions.
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
