cgal-discuss - [cgal-discuss] literature
  • To: "" <>
  • Subject: [cgal-discuss] literature
  • Date: Thu, 25 Feb 2010 08:23:31 +0100
Dear CGAL community,
For a literature review, I would like to ask a number of things which are still not really clear for me after studying the manual and doing some literature searches:
Regarding the straight skeleton:
* The runtime complexity of the straight skeleton, is it indeed O(nr + n log n), with n = total nb vertices and r = nb reflex vertices, like in the implementation of Felkel?
* What publication can I best refer to address its runtime complexity (as its not mentioned in the manual)?
Regarding the hilbert_sort and spatial_sort algorithms:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Spatial_sorting/Chapter_main.html
* Here also: what is their runtime complexity?
* Are there publications that explain the algorithms used and provide some benchmarks on spatial locality improvement?
Thanks a lot!
Maarten Moesen
You may find the answer to your question
in the CGAL documentation.
I quote below the definition of Alpha-shapes in CGAL's user manual
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Alpha_shapes_3/Chapter_main.html
More precisely, the definition of alpha shapes is based on an underlying triangulation that may be a Delaunay triangulation in case of basic alpha shapes or a regular triangulation (cf. 35.3) in case of weighted alpha shapes.
Let us consider the basic case with a Delaunay triangulation. We first define the alpha complex of the set of points S. The alpha complex is a subcomplex of the Delaunay triangulation. For a given value of α, the alpha complex includes all the simplices in the Delaunay triangulation which have an empty circumsphere with squared radius equal or smaller than α. Here ``empty'' means that the open sphere do not include any points of S. The alpha shape is then simply the domain covered by the simplices of the alpha complex (see [EM94]).
mahdavi wrote:
hi all
I use alpha complex ,my program is used regular triangulation for weighted
points and I want to grow points by constant alpha(a). please anybody say
me that in weighted alpha complex must be used alpha or square alpha ,
Which is instruction correct?
1:Alpha_shape_3 as(P1.begin(), P1.end(), a, Alpha_shape_3::GENERAL);
2:Alpha_shape_3 as(P1.begin(), P1.end(), a^2 ,Alpha_shape_3::GENERAL);
thanks.
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
Maarten Moesen, PHD
Department of Metallurgy and Materials Engineering (MTM)
K.U.Leuven
Kasteelpark Arenberg 44 - Bus 02450
B-3001 Heverlee, Belgium
tel. +32 (0)16 32 13 17
fax. +32 (0)16 32 19 90
