- To:
- Subject: Re: [cgal-discuss] Floating Point Exception Handling
- Date: Mon, 1 Mar 2010 22:06:44 +0100
Le Lundi 01 Mars 2010 20:31:59, Panagiotis Foteinos a écrit :
> Hello all.
> I am using the 3D Delaunay Triangulation package with a custom refinement
> algorithm. In my program, there are almost flat elements which I want to
> identify as flat (by checking the volume for example), and leave them alone
> without performing any calculations on them any more. The problem is that
> the calculation of the circumcenter or the radius (and the volume as a
> consequence)
The volume is a not a consequence of the circumcenter or the radius of a
tetrahedron. The volume is one sixth of the mixed product:
http://en.wikipedia.org/wiki/Tetrahedron#Volume
http://en.wikipedia.org/wiki/Mixed_product#Scalar_triple_product
There is no need to compute a division to compute the volume.
In contrary, to compute the circumcenter or the circumradius of a
tetrahedron,
the denominator is the mixed product, if I remember well.
Use CGAL::volume(Point_3, Point_3, Point_3, Point_3):
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Kernel_23_ref/Function_volume.html
Laurent Rineau, PhD
- [cgal-discuss] Floating Point Exception Handling, Panagiotis Foteinos, 03/01/2010
- Re: [cgal-discuss] Floating Point Exception Handling, Eric Berberich, 03/01/2010
- Re: [cgal-discuss] Floating Point Exception Handling, Panagiotis Foteinos, 03/01/2010
- Re: [cgal-discuss] Floating Point Exception Handling, Andreas Fabri, 03/02/2010
- Re: [cgal-discuss] Floating Point Exception Handling, Laurent Rineau (GeometryFactory), 03/01/2010
