- To:
- Subject: Re: [cgal-discuss] Incorrect #include in CGAL-3.6beta1 Polyhedron demo
- Date: Tue, 02 Mar 2010 19:47:14 +0100
Hi,
Laurent Rineau (GeometryFactory) wrote:
> On Monday 01 March 2010 19:09:23 Daniel Sieger wrote:
>> Hi,
>> I just tried to compile the Polyhedron demo from CGAL-3.6beta1. There seems
>> to be an incorrect #include statement in
>> Polyhedron_demo_mesh_3_plugin_cgal_code.cpp line 35:
>> #include <Qt/qglobal.h>
>> I think this should be either
>> #include <QtCore/qglobal.h>
>> or
>> #include <QtGlobal>
Don't you mean <QtCore/QtGlobal> here, unless you pass multiple -I
statements for each QtFoo directory?
> On Linux, <Qt/qglobal.h> is valid also. That is the flat layout of Qt
> header
> (created with the script bin/syncqt from Qt tarball).
> I think you are right that we should use either <QtCore/qglobal.h> or
> <QtGlobal>, but I cannot find where, in Qt documentation, it is explained.
> Do
> you have a pointer?
> Anyway, that will be fixed.
Searching for qglobal.h and QtGlobal I find on my system:
(1) /usr/include/qt4/QtCore/QtGlobal
(2) /usr/include/qt4/Qt/qglobal.h
(3) /usr/include/qt4/QtCore/qglobal.h
(1) includes "qglobal.h", (2) and (3) are identical
Therefore,
(a) #include <QtCore/QtGlobal>
(b) #include <Qt/qglobal.h>
(c) #include <QtCore/qglobal.h>
should all work.
In particular, the code you pointed out should work without problems.
And as Laurent mentioned, can you point out why one of the methods
should be preferred over the other two? ((a) adds an additional
indirection, ok).
BTW the Qt tutorials use <QtGlobal>, expecting to pass
-I/usr/include/qt4/Qt or multiple -I/usr/include/qt4/QtFoo statements.
Joachim
- [cgal-discuss] Incorrect #include in CGAL-3.6beta1 Polyhedron demo, Daniel Sieger, 03/01/2010
- Re: [cgal-discuss] Incorrect #include in CGAL-3.6beta1 Polyhedron demo, Laurent Rineau (GeometryFactory), 03/02/2010
- Re: [cgal-discuss] Incorrect #include in CGAL-3.6beta1 Polyhedron demo, Daniel Sieger, 03/02/2010
- Re: [cgal-discuss] Incorrect #include in CGAL-3.6beta1 Polyhedron demo, Joachim Reichel, 03/02/2010
- Re: [cgal-discuss] Incorrect #include in CGAL-3.6beta1 Polyhedron demo, Laurent Rineau (GeometryFactory), 03/23/2010
- Re: [cgal-discuss] Incorrect #include in CGAL-3.6beta1 Polyhedron demo, Daniel Sieger, 03/23/2010
