cgal-discuss - Re: [cgal-discuss] degenerate beziers in an arrangement
  • To:
  • Subject: Re: [cgal-discuss] degenerate beziers in an arrangement
  • Date: Wed, 3 Mar 2010 09:48:30 -0300
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type :content-transfer-encoding; b=d8ic4X1nsvZ+AxXd/ed8Ad1NslxWiZWRMR4RkuKT7JH2vSfziVzQ2PxpHnkzPWYBrC nXDPooDY6yRWeS14Uyi3E9WC+RvySC81G6yRdtGqL8Cw/DNCfJIRjBhxmAEEXrziByZQ YKKe1JkThONHgV13tusV0IS5p31xwFDm7BpVY=
Hi Ben,
> always cubics.  But...sometimes either C1==P1 or C2==P2.
I guess then that for your application the quadratic (P0,P1,P2) isn't
the same as the cubic (P0,P1,P2,P2)?
AFAICT they would both render the same (or maybe not? I never tried
such a degenerate cubic).
Anyway, in CGAL you just can't construct an N-degree bezier with only
M<N distinct control points. The degree is given by that count, so in
your case you're stuck with quadratics.
HTH
Fernando Cacciola
GeometryFactory
