- To:
- Subject: [cgal-discuss] self-intersecting beziers and arrangement algorithms
- Date: Wed, 03 Mar 2010 09:55:54 -0500
Hi Y'all,
I am using the bezier curve traits with the sweep algorithm to find intersections in closed bezier general polygons.
The manual for the bezier traits curve_2 says:
"The only resriction we have is that the curve does not contain any self-intersections."
The precondition for the constructor says:
"The input range must contain at least two control points, and the polyline defined by these points must not be self-intersecting."
But...from what I can tell:
- The sweep line at least works correctly even if either of these preconditions is violated.
- The code appears to at least intentionally handle the first case (self-intersections).
Is this a case of (a) the manual over-states the preconditions or (b) the code does not check the preconditions, and may be functioning incorrectly in a way I have not detected?
Thanks!!!
Ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] self-intersecting beziers and arrangement algorithms, Ben Supnik, 03/03/2010
- Re: [cgal-discuss] self-intersecting beziers and arrangement algorithms, Efraim Fogel, 03/03/2010
