cgal-discuss - Re: [cgal-discuss] Setting up cmake
  • To:
  • Subject: Re: [cgal-discuss] Setting up cmake
  • Date: Thu, 04 Mar 2010 13:59:48 +0100
Martin Baeker wrote:
Dear all,
I have a program library based on CGAL3.3. It consists of several
C++-Classes, each with its own .hpp and .cpp-file.
I am at a loss on how to achieve the same thing with newer versions of
CGAL that use cmake. The cgal_create_cmake_script is not sufficient because
I need to link to the library from my classes together when building
an executable. OTOH, I need correct compilation with all CGAL-stuff as
well.
Here is a very simple example (not meaningfulin itself) of what I want to do:
File Pointclass.H
#include <CGAL/Gmpq.h>
#include <CGAL/Cartesian.h>
typedef CGAL::Cartesian<CGAL::Gmpq> Kernel;
typedef Kernel::Point_3 Point;
class Mypoint: public Point
public:
int index;
Mypoint(int in);
File Pointclass.C
#include "Pointclass.H"
Mypoint::Mypoint(int in)
index = in;
File main.C
int main()
Mypoint p(1);
std::cout << p.index << std::endl;
return 0;
So how do I set up cmake so that main can be linked to Pointclass and
that the dependence of the two is known?
I suppose there is a simple way how to do this, but I'm not able to
find it...
Thanks for any help,
if you switch to CGAL-3.4 (or better upcoming 3.6) there is
cgal_create_cmake_script located in scripts subdir that does the job for you, i.e., write a proper CMakeLists.txt file.
eriC
Martin.
Priv.-Doz. Dr. Martin Bäker
Institut für Werkstoffe
Technische Universität Braunschweig
Langer Kamp 8
38106 Braunschweig
Germany
Tel.: 00-49-531-391-3073
Fax 00-49-531-391-3058
e-mail
