cgal-discuss - [cgal-discuss] CUDA - CGAL compilation
  • To:
  • Subject: [cgal-discuss] CUDA - CGAL compilation
  • Date: Thu, 4 Mar 2010 14:58:42 -0800 (PST)
Hi All,
Were any of you able to compile CGAL (and also Boost) code along with the
device code in a '.cu' file in CUDA environment? The only solution which I
found was to write host code and device code separately in a .cpp file and
.cu file, compile it with 'gcc' and 'nvcc' respectively, and finally link
them.
Regards,
Nikhil Navkar
View this message in context:
http://n4.nabble.com/CUDA-CGAL-compilation-tp1578938p1578938.html
  • [cgal-discuss] CUDA - CGAL compilation, Nikhil Navkar, 03/04/2010
