cgal-discuss - Re: [cgal-discuss] normal vector of a facet
  • To:
  • Subject: Re: [cgal-discuss] normal vector of a facet
  • Date: Fri, 5 Mar 2010 15:24:41 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=oQ0mG/hA7VgUUaPGQxLnq7Hmn7haIFNNnH3+MhJzy2ptDrVKCV9naebdDAB4+Ko9zP GwUhTM9K6KGn5ZFG+D5VnyhpirEbKtgKClktUQicrvFDskOQqjBRuRq9q8Cyt4brU5lI U6iMC/V40JVVDExhetjZNtEm6OV1J+1AmscvU=
Thanks for responding Laurent.
I am adding a new facet criterion class to mesh_standard_facet_criteria.h
In the do_is_bad(const Facet& f) function, I need to calculate the normal vector of the facet (assuming the normal vector points outwards from the inside of the domain).  Then I will use this normal vector to do some other calculations...
Assuming the right hand rule for finding the direction of the normal, will CGAL::normal(p1, p2, p3) produce a vector that points in the correct direction?
-Ramin
On Fri, Mar 5, 2010 at 3:01 PM, Laurent Rineau (GeometryFactory) <> wrote:
Le Vendredi 05 Mars 2010 20:16:56, Ramin H a écrit :
> Hi everyone,
> I have the handle to a facet of a 3D triangulation and would like to find
> the normal vector of the facet. This is how I am doing it but it looks like
> the normal is incorrect.
> // const Facet& f is passed to this function in the function argument ...
> const Point_3& p1 = f.first->vertex((f.second+1)&3)->point();
> const Point_3& p2 = f.first->vertex((f.second+2)&3)->point();
> const Point_3& p3 = f.first->vertex((f.second+3)&3)->point();
> Vector_3 v1 = CGAL::normal(p1, p2, p3);
> Am I missing something?
> -Ramin
Hi Ramin,
Who wrong is the normal vector you get? The computation seems right.
Did you want a *unit* normal vector? Did you want coherent orientations of all
the normal vector you compute?
Laurent Rineau, PhD
Release Manager of the CGAL Project       http://www.cgal.org/
R&D
Engineer at GeometryFactory           http://www.geometryfactory.com/
