- To:
- Subject: [cgal-discuss] Bezier curve arrangement error
- Date: Wed, 10 Mar 2010 10:06:09 -0800 (PST)
I'm testing the example program
examples/Arrangement_on_surface_2/Bezier_curves.cpp
using input:
2
2 256 0 0 0
4 215 175 251 100 214 25 205 0
I get the following exception:
$ Bezier_curves test1.dat
B = {2 256 0 0 0}
B = {4 215 175 251 100 214 25 205 0}
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: nt_traits.degree (*p_polyY) >= 0
File: /usr/include/CGAL/Arr_geometry_traits/Bezier_curve_2.h
Line: 767
Abort
Note that the target point of the cubic curve is collinear with the
endpoints of the degree-1 curve. Is it significant?
Here is a similar example that does not throw an exception:
2
2 256 0 0 0
4 56 144 37 94 96 21 118 0
B = {2 256 0 0 0}
B = {4 56 144 37 94 96 21 118 0}
The arrangement size:
V = 5, E = 4, F = 1
What am I missing?
Thanks,
Gene
View this message in context:
http://n4.nabble.com/Bezier-curve-arrangement-error-tp1587812p1587812.html
- [cgal-discuss] Bezier curve arrangement error, Gene, 03/10/2010
