cgal-discuss - Re: [cgal-discuss] Ask:is there a bug in the intersection function
  • To: "cgal-discuss" <>
  • Subject: Re: [cgal-discuss] Ask:is there a bug in the intersection function
  • Date: Fri, 12 Mar 2010 17:12:06 +0800
thanks for your timely and effective reply!
------------------ Original ------------------
Date:  Fri, Mar 12, 2010 04:42 PM
To:  "cgal-discuss"<>;
梓桥 wrote:
> Hello!
> Every one,is there a bug in the intersection function? why the following
> code result in "no intersection"? actually the two line intersects.
> best regards!
Please have a look at this FAQ entry:
http://www.cgal.org/FAQ.html#inexact_NT
S.
> CGAL::Point_2<Kernel> point;
>     CGAL::Segment_2<Kernel> seg;
>     Segment_2 iseg(Point_2(106.38,90.94),Point_2(106.38,91.12));
>     K::Vector_2 v=K::Vector_2(Point_2(69.72,82.12),Point_2(150.26,117.86));
>     Ray_2 parelleline(Point_2(86.4848,82.12),v);
>     CGAL::Object o=intersection (iseg, parelleline);
>     if (CGAL::assign(seg, o)){
>         std::cout<<"the intersection is a segment";
>     }else if(CGAL::assign(point, o))    {
>         std::cout<<"the intersection is a point: "<<point.x()<<"
> "<<point.y();
>     }else
>         std::cout<<"no intersection";
