- To: <>
- Subject: RE: [cgal-discuss] CGAL_Qt4-vc90-mt-sgd.lib
- Date: Fri, 12 Mar 2010 14:11:28 +0100
- Importance: Normal
Just one precision: what i said below is true in Debug mode (as Laurent RINEAU mentionned in a previous mail). Youssef ALJ From: To: Date: Fri, 12 Mar 2010 14:07:38 +0100 Subject: RE: [cgal-discuss] CGAL_Qt4-vc90-mt-sgd.lib I resolved the problem. The solution to this problem (for further questions) is only due to runtime library compatibilty between CGAL and other projects using CGAL. One has to check that all projects (or at least projects using CGAL) are set with Multi-threaded Debug DLL (/MDd) runtime library. Thanks anyway for you precious help. Best regards! Youssef ALJ > From: > To: > Date: Fri, 12 Mar 2010 11:10:43 +0100 > CC: > Subject: Re: [cgal-discuss] CGAL_Qt4-vc90-mt-sgd.lib > > On Friday 12 March 2010 11:03:42 Youssef ALJ wrote: > > Actually from the qt website i installed the following product: > > > > Qt libraries 4.6.2 for Windows (VS 2008, 194 MB) > > > > is this what you mean by QT4? > > Yes, that is what I meant. > > > if it is the case, it is recognized while > > configuring CGAL with CMAKE. > > Maybe Andreas had the right answer: probably you have compiled CGAL libraries > in Release mode, and you are trying to build your demo in another mode. > > > May be i should install the whole QT SDK, > > what do you think? > > No, that is OK. > > -- > Laurent Rineau, PhD > R&D Engineer at GeometryFactory http://www.geometryfactory.com/ > Release Manager of the CGAL Project http://www.cgal.org/ > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss > Hotmail: Free, trusted and rich email service. Get it now. Hotmail: Powerful Free email with security by Microsoft. Get it now. |
- [cgal-discuss] CGAL_Qt4-vc90-mt-sgd.lib, youssef_alj, 03/11/2010
- Re: [cgal-discuss] CGAL_Qt4-vc90-mt-sgd.lib, Mohamed Yousef, 03/11/2010
- RE: [cgal-discuss] CGAL_Qt4-vc90-mt-sgd.lib, Youssef ALJ, 03/12/2010
- Re: [cgal-discuss] CGAL_Qt4-vc90-mt-sgd.lib, Laurent Rineau (GeometryFactory), 03/12/2010
- Re: [cgal-discuss] CGAL_Qt4-vc90-mt-sgd.lib, Andreas Fabri, 03/12/2010
