- To:
- Subject: Re: [cgal-discuss] Boundary constrained tetrahedra mesh generation
- Date: Sat, 13 Mar 2010 10:47:40 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=FngZVbmJrOdI1AEBd6+Z8v4Limm9+o9R0exDfAIYNxLvaoBphR+njSalRvyesn5orm y1s4Q2sFc5xgeJrnbena1XxcawfoU3tIHzjwB/Ex7/YIacBDpOObm7hdEceznYvuLCag dwlaTBGVx4jiXg2Xitwz5OFJnc6BYk7XdRPhk=
Hi wlzhu,
As far as I know, the current 3D mesh generation algorithm does not allow this.
Your boundaries define a polyhedral domain that will guide the meshing algorithm to weave a tetrahedra mesh inside the domain. You can not keep the polyhedra as your surface mesh.
Regards,
-Ramin
On Sat, Mar 13, 2010 at 8:50 AM, wlzhu <> wrote:
Dear all,
Is there any way to generate a tetrahedron mesh with given two boundary triangle meshs.
For instance two sphere surfaces with different radius, we want to generate a tetrahedra mesh without changing the input triangle mesh.
thanks
- [cgal-discuss] Boundary constrained tetrahedra mesh generation, wlzhu, 03/13/2010
- Re: [cgal-discuss] Boundary constrained tetrahedra mesh generation, Ramin H, 03/13/2010
