cgal-discuss - Re: [cgal-discuss] multidomain meshing of polyhedral surfaces
  • To:
  • Subject: Re: [cgal-discuss] multidomain meshing of polyhedral surfaces
  • Date: Mon, 15 Mar 2010 13:24:05 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=vhWpOE/a066bbKawLZFBX/7WSXbnT3SYC1KhBu0z34l5A1Vb41PwUL1TxHcoVjpdgq Fgn10L/HUKv0CpnEHXoxAYGA9Yn7iY+FO1Wq7RZAgqr/ukWV6/xSU4mz+AZFFrNkN8O/ 5eWHnak5k3NbmuZWeNSnLDk2nfTfiUrl9J74s=
Hi toddoe,
The current version does not have an oracle for multidomain from a set of polyhedra. You need to write your own oracle for this.
-Ramin
On Mon, Mar 15, 2010 at 12:01 PM, toddoe <> wrote:
hi,
i know you can make a multidomain mesh from a voxel image, but can you make
a multidomain mesh from a set of polyhedral surfaces? It looks possible, but
I can't really tell from the code or manual. Is there an example of this
anywhere?
thanksinadvance!
View this message in context: http://n4.nabble.com/multidomain-meshing-of-polyhedral-surfaces-tp1593593p1593593.html
