- To: , , ,
- Subject: [cgal-discuss] CGAL 3.6 Released, Computational Geometry Algorithms Library
- Date: Mon, 22 Mar 2010 15:16:25 +0100
The CGAL Open Source Project is pleased to announce the Release 3.6
of CGAL, the Computational Geometry Algorithms Library.
Besides improvements and fixes to existing packages, this release offers
the following new features.
o 3D Periodic Triangulations
The package can now be used with the 3D Alpha Shapes package to compute
periodic alpha shapes.
o 3D Mesh Generation
The mesh generator has been enriched with an optimization phase to
provide 3D meshes with well shaped tetrahedra (and in particular no
slivers).
o Algebraic Kernel (new package)
This new package provides implementations of algorithms to determine,
compare and approximate real roots of univariate polynomials and
bivariate polynomial systems.
See http://www.cgal.org/releases.html for a complete list of changes.
The CGAL project is a collaborative effort to develop a robust,
easy-to-use, and efficient C++ software library of geometric data
structures and algorithms, like
- triangulations (2D constrained triangulations and Delaunay
triangulations in 2D and 3D),
- Voronoi diagrams (for 2D and 3D points, 2D additively weighted
Voronoi diagrams, and segment Voronoi diagrams),
- Boolean operations on polygons and polyhedra,
- Regularized Boolean operations on polygons with curved arcs
- arrangements of curves,
- mesh algorithms (2D Delaunay mesh generation and 3D surface mesh
generation, surface mesh subdivision and parameterization),
- alpha shapes (in 2D and 3D),
- convex hull algorithms (in 2D, 3D and dD),
- operations on polygons (straight skeleton and offset polygon),
- search structures (kd trees for nearest neighbor search, and
range and segment trees),
- interpolation (natural neighbor interpolation and placement of
streamlines),
- optimization algorithms (smallest enclosing sphere of points or
spheres, smallest enclosing ellipsoid of points, principal
component analysis),
- kinetic data structures
Some modules are distributed under the terms of the LGPL Open Source
license (GNU Lesser General Public License v2.1).
Most modules are distributed under the terms of the QPL Open Source
license (Q Public License v1.0).
If your intended usage does not meet the criteria of the
aforementioned licenses, a commercial license can be purchased from
GeometryFactory (http://www.geometryfactory.com/).
For further information and for downloading the library and its
documentation, please visit the CGAL web site: http://www.cgal.org/
Laurent Rineau, PhD
- [cgal-discuss] CGAL 3.6 Released, Computational Geometry Algorithms Library, Laurent Rineau (GeometryFactory), 03/22/2010
