- To:
- Subject: Re: [cgal-discuss] Mesh 2D test
- Date: Fri, 26 Mar 2010 12:45:22 +0100
On Friday 26 March 2010 12:28:00 Laurent Rineau (GeometryFactory) wrote:
> If "fit" is a handle (or iterator) to a facet, then "fit->is_in_domain()"
> is true if and only if the facet is in the mesh domain (I assume that what
> you call "the mesh" is what I call "the mesh domain").
As a matter of fact, I have modified the example mesh_with_seeds.cpp of
Mesh_2, to show how to use is_in_domain.cpp. It will be in next releases of
CGAL (soon in 3.6.1 and in 3.7 in six months). You can find the new version
of
that file attached.
Laurent Rineau, PhD
#include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Constrained_Delaunay_triangulation_2.h> #include <CGAL/Delaunay_mesher_2.h> #include <CGAL/Delaunay_mesh_face_base_2.h> #include <CGAL/Delaunay_mesh_size_criteria_2.h> #include <iostream> typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef CGAL::Triangulation_vertex_base_2<K> Vb; typedef CGAL::Delaunay_mesh_face_base_2<K> Fb; typedef CGAL::Triangulation_data_structure_2<Vb, Fb> Tds; typedef CGAL::Constrained_Delaunay_triangulation_2<K, Tds> CDT; typedef CGAL::Delaunay_mesh_size_criteria_2<CDT> Criteria; typedef CDT::Vertex_handle Vertex_handle; typedef CDT::Point Point; int main() { CDT cdt; Vertex_handle va = cdt.insert(Point(2,0)); Vertex_handle vb = cdt.insert(Point(0,2)); Vertex_handle vc = cdt.insert(Point(-2,0)); Vertex_handle vd = cdt.insert(Point(0,-2)); cdt.insert_constraint(va, vb); cdt.insert_constraint(vb, vc); cdt.insert_constraint(vc, vd); cdt.insert_constraint(vd, va); va = cdt.insert(Point(3,3)); vb = cdt.insert(Point(-3,3)); vc = cdt.insert(Point(-3,-3)); vd = cdt.insert(Point(3,0-3)); cdt.insert_constraint(va, vb); cdt.insert_constraint(vb, vc); cdt.insert_constraint(vc, vd); cdt.insert_constraint(vd, va); std::list<Point> list_of_seeds; list_of_seeds.push_back(Point(0, 0)); std::cout << "Number of vertices: " << cdt.number_of_vertices() << std::endl; std::cout << "Meshing the domain..." << std::endl; CGAL::refine_Delaunay_mesh_2(cdt, list_of_seeds.begin(), list_of_seeds.end(), Criteria()); std::cout << "Number of vertices: " << cdt.number_of_vertices() << std::endl; std::cout << "Number of finite faces: " << cdt.number_of_faces() << std::endl; int mesh_faces_counter = 0; for(CDT::Finite_faces_iterator fit = cdt.finite_faces_begin(); fit != cdt.finite_faces_end(); ++fit) { if(fit->is_in_domain()) ++mesh_faces_counter; } std::cout << "Number of faces in the mesh domain: " << mesh_faces_counter << std::endl; }
- [cgal-discuss] Mesh 2D test, N2a, 03/26/2010
- Re: [cgal-discuss] Mesh 2D test, Laurent Rineau (GeometryFactory), 03/26/2010
- Re: [cgal-discuss] Mesh 2D test, Benjamin Bouscasse, 03/26/2010
