- To: <>
- Subject: RE: [cgal-discuss] CGAL with Visual Studio 2008
- Date: Mon, 29 Mar 2010 21:40:19 +0200
- Importance: Normal
It's probably due to runtime library compatibility between your project and CGAL library. Hi, Right-click your project in Solution Explorer and click Properties and then go to Configuration Properties->C/C++->Code Generation->Runtime Library: if you compile your project in Debug mode select /MDd and /MD if you compile it in release mode. This may fix your problem. Best regards, Youssef ALJ > To: > From: > Date: Mon, 29 Mar 2010 19:56:01 +0200 > Subject: [cgal-discuss] CGAL with Visual Studio 2008 > > Hi, > > I am trying to compile a code that uses Qt and Cgal on Windows 7 with Visual > Studio 2008. I had many linking errors and I tried to solve most of them. > However, I have the following link errors which I could not solve for a long > time now: > > 1>wrapped_helpers.obj : error LNK2019: unresolved external symbol "void __cdecl > CGAL::postcondition_fail(char const *,char const *,int,char const *)" > (?postcondition_fail@CGAL@@YAXPBD0H0@Z) referenced in function "class > std::back_insert_iterator<class QVector<class CGAL::Point_2<struct > CGAL::Filtered_kernel<struct CGAL::Simple_cartesian<double> > > > > __cdecl > CGAL::ch_akl_toussaint<class CGAL::Point_2<struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > > *,class std::back_insert_iterator<class > QVector<class CGAL::Point_2<struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > > > >,struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > >(class CGAL::Point_2<struct > CGAL::Filtered_kernel<struct CGAL::Simple_cartesian<double> > > *,class > CGAL::Point_2<struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > > *,class std::back_insert_iterator<class > QVector<class CGAL::Point_2<struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > > > >,struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > const &)" > (??$ch_akl_toussaint@PAV?$Point_2@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@CGAL@@@CGAL@@V?$back_insert_iterator@V?$QVector@V?$Point_2@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@CGAL@@@CGAL@@@@@std@@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@2@@CGAL@@YA?AV?$back_insert_iterator@V?$QVector@V?$Point_2@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@CGAL@@@CGAL@@@@@std@@PAV?$Point_2@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@CGAL@@@0@0V12@ABU?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@0@@Z) > 1>wrapped_helpers.obj : error LNK2019: unresolved external symbol "void __cdecl > CGAL::assertion_fail(char const *,char const *,int,char const *)" > (?assertion_fail@CGAL@@YAXPBD0H0@Z) referenced in function "bool __cdecl > CGAL::get_certain<bool>(class CGAL::Uncertain<bool>)" > (??$get_certain@_N@CGAL@@YA_NV?$Uncertain@_N@0@@Z) > 1>wrapped_helpers.obj : error LNK2019: unresolved external symbol "void __cdecl > CGAL::precondition_fail(char const *,char const *,int,char const *)" > (?precondition_fail@CGAL@@YAXPBD0H0@Z) referenced in function "class > CGAL::Tee_for_output_iterator<class std::back_insert_iterator<class > QVector<class CGAL::Point_2<struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > > > >,class CGAL::Point_2<struct > CGAL::Filtered_kernel<struct CGAL::Simple_cartesian<double> > > > __cdecl > CGAL::ch__ref_graham_andrew_scan<class std::_Vector_iterator<class > CGAL::Point_2<struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > >,class std::allocator<class > CGAL::Point_2<struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > > > >,class > CGAL::Tee_for_output_iterator<class std::back_insert_iterator<class > QVector<class CGAL::Point_2<struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > > > >,class CGAL::Point_2<struct > CGAL::Filtered_kernel<struct CGAL::Simple_cartesian<double> > > >,struct > CGAL::Filtered_kernel<struct CGAL::Simple_cartesian<double> > >(class > std::_Vector_iterator<class CGAL::Point_2<struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > >,class std::allocator<class > CGAL::Point_2<struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > > > >,class std::_Vector_iterator<class > CGAL::Point_2<struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > >,class std::allocator<class > CGAL::Point_2<struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > > > >,class > CGAL::Tee_for_output_iterator<class std::back_insert_iterator<class > QVector<class CGAL::Point_2<struct CGAL::Filtered_kernel<struct > CGAL::Simple_cartesian<double> > > > >,class CGAL::Point_2<struct > CGAL::Filtered_kernel<struct CGAL::Simple_cartesian<double> > > > &,struct > CGAL::Filtered_kernel<struct CGAL::Simple_cartesian<double> > const &)" > (??$ch__ref_graham_andrew_scan@V?$_Vector_iterator@V?$Point_2@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@CGAL@@@CGAL@@V?$allocator@V?$Point_2@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@CGAL@@@CGAL@@@std@@@std@@V?$Tee_for_output_iterator@V?$back_insert_iterator@V?$QVector@V?$Point_2@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@CGAL@@@CGAL@@@@@std@@V?$Point_2@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@CGAL@@@CGAL@@@CGAL@@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@4@@CGAL@@YA?AV?$Tee_for_output_iterator@V?$back_insert_iterator@V?$QVector@V?$Point_2@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@CGAL@@@CGAL@@@@@std@@V?$Point_2@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@CGAL@@@CGAL@@@0@V?$_Vector_iterator@V?$Point_2@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@CGAL@@@CGAL@@V?$allocator@V?$Point_2@U?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@CGAL@@@CGAL@@@std@@@std@@0AAV10@ABU?$Filtered_kernel@U?$Simple_cartesian@N@CGAL@@@0@@Z) > 1>bin\debug\symage.exe : fatal error LNK1120: 3 unresolved externals > > Before I had also some link errors with gmp libraries but then I read that even > though my operating system is 64 bits, I should install CGAL with 32 bits > option. I reinstalled CGAL with 32 bits and got rid of the link errors about > gmp. > > The version of CGAL I am using is 3.5.1. I would be really glad if anyone can > help. > > Thanks a lot, > Duygu > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss > Hotmail: Free, trusted and rich email service. Get it now. |
- [cgal-discuss] CGAL with Visual Studio 2008, duygu.ceylan, 03/29/2010
- RE: [cgal-discuss] CGAL with Visual Studio 2008, Youssef ALJ, 03/29/2010
- Re: [cgal-discuss] CGAL with Visual Studio 2008, Duygu Ceylan, 03/29/2010
