- To:
- Subject: Re: [cgal-discuss] Oil, Blue Fin Tuna, and the CGAL Surface Mesh Generator
- Date: Thu, 1 Apr 2010 17:58:24 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=idTYjKh0vRJrh1cNvD2tT2VHLXBS9Uq9H52FOv/mkZ0ErfW7X412ivmO71nJR4x6aB zW30s29WTyLRBXM6p6YLHXhOVps5V+XRuAFyo7CZZqDYVMCUeuoZHEiBjQvLCIbh1l95 EOouBTVhSSFVScmXQiV15nBJwD8re9quQkBRQ=
But seriously, I'm having problems using homogeneous kernel with
integer coordinates in boolean polygon operations, which means my
application computing the optimal way to skin pandas (Ailuropoda
melanoleuca) will not be fast enough :(
- [cgal-discuss] Oil, Blue Fin Tuna, and the CGAL Surface Mesh Generator, Andreas Fabri, 04/01/2010
- Re: [cgal-discuss] Oil, Blue Fin Tuna, and the CGAL Surface Mesh Generator, Remi, 04/01/2010
- Re: [cgal-discuss] Oil, Blue Fin Tuna, and the CGAL Surface Mesh Generator, Yang Liu, 04/01/2010
- Re: [cgal-discuss] Oil, Blue Fin Tuna, and the CGAL Surface Mesh Generator, Cornelia Auer, 04/01/2010
- Re: [cgal-discuss] Oil, Blue Fin Tuna, and the CGAL Surface Mesh Generator, avaxman, 04/01/2010
