cgal-discuss - Re: [cgal-discuss] Re: Help: how to load 3D tet mesh from file into c3t3 (sorry if noob)
  • To:
  • Subject: Re: [cgal-discuss] Re: Help: how to load 3D tet mesh from file into c3t3 (sorry if noob)
  • Date: Fri, 2 Apr 2010 12:00:19 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=DfySaj0MT+PjUQnd2jYn3PPyu+Mjeluxp9QRlx+ARvBkuj3MP1F8VVkDxe4JKUMszm cYIJiuwsuNl5mg0jGhrz++YC3ck3YmzIvceW+92pDoQ3ESb2qslr4OdUAD3nhPl5qYP3 9JwV0HRm10jD72aWUMGfrmh0fBkg2eyilA8N8=
Thanks Laurent.
I am on a Windows machine. I will find out how to use patch on Windows.
I am using CGAL-3.5.1. I hope the patch works for this version as well.
-Ramin
On Fri, Apr 2, 2010 at 11:40 AM, Laurent Rineau (GeometryFactory) <> wrote:
Le Vendredi 02 Avril 2010 17:17:24, Ramin H a écrit :
> template < class GT, class Tds >
> std::istream &
> operator>> (std::istream& is, Triangulation_3<GT, Tds> &tr)
> in Triangulation_3.h is missing the code that should read those indexes.
> but operator<< is writing "the non combinatorial information on the cells".
> Is there a patch that I can apply and resolve this issue?
Yes. Sorry I was too busy to handle that today.
Here is a patch from my own copy of Mesh_3, to be applied in the CGAL
installation with the following command line:
 patch -p0 < Mesh_3.patch
The patch is made against the (internal) development version CGAL-3.7-I, but
you can probably apply it against CGAL-3.6 as well. If you are not used to
"patch",  I can send the patched files instead.
I have tested that patch will binary I/O.
Laurent Rineau, PhD
Release Manager of the CGAL Project       http://www.cgal.org/
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
