- To:
- Subject: [cgal-discuss] Tetrahedral mesh from polyhedral and image domain
- Date: Tue, 6 Apr 2010 13:52:37 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=jstBjqSfX4UoDsPSXo54q61Fl6CdCLoY0kCyfMFghnrrxoLR97ltldLVjV/viNExVf DkIW5eewxTiIbjGyz3FCvvOE2D+30OeaU24OC7cyizWpXfe3jsMldiHqMBz2lZc0tn9Z vWV8OtypXgt3Red9qLjdIsm1NBHypRQ2SJXqg=
Hi all,
I am getting familiar with CGAL recently and I have some questions on 3D Mesh generation package:
Q1. Is it possible to generate a volumetric tetrahedral mesh from triangulated surface, but having the surface triangles not changed, only tetrahedral elements inside the volume remeshed.
Q2. When I use the mesh_3D_image example for finer mesh resolution (0.3 mm - facet size and cell size) , I get the mesh with jagged boundaries (see the fig attached), and
if I want to have smoother mesh I do give larger facet_distance to have low approximation, but still I have the same problem of jagged boundaries.
Q3. For generating meshes from the segmented image, Is it possible to control the parameters (facet_size,cell_size, etc) for each segmented region individually?
I thank you a lot in advance to help me with these questions.
Cheers.
Jatin
Description: JPEG image
- [cgal-discuss] Tetrahedral mesh from polyhedral and image domain, jatin relan, 04/06/2010
- Re: [cgal-discuss] Tetrahedral mesh from polyhedral and image domain, Stephane Tayeb, 04/07/2010
