- To: "" <>
- Subject: Re: [cgal-discuss] Help for Voronoi
- Date: Fri, 09 Apr 2010 08:42:31 +0100
- Bounce-to: "Daniel Duque" <>
Hello,
I am not sure I understand the question, but perhaps it is the same one I
have been considering for a while: a Voronoi diagram inside a rectangle.
I think one would have to check whether the nodes of the Voronoi lattice
(the circumcenters of the Delaunay triangles) lie inside or outside the
rectangle. If the later applies, one has to consider the intersection of
the Voronoi edges with the rectangle in order to build not-so-Voronoi
cells for the vertices of the Delaunay triangle.
Best,
Daniel
Con fecha 8/4/2010, "杨成林"
escribió:
>To make it easier, the points of intersection are not necessary. Just put
>another vertex of the edge outside the rectangle.
>2010/4/8 Bo Zhou
>> Laurent Rineau (GeometryFactory) wrote:
>>> You've already been told to post in English only, on that list. Please
>>> respect that guideline.
>>> (I did not understand the question of Bo either.)
>>> Le Mercredi 07 Avril 2010 14:56:41, Ñî³ÉÁÖ a ¨¦crit :
>>>> û¿´¶®ÄãµÄÎÊÌâ
>>>> 2010/4/7 Bo Zhou
>>>>> Hello everyone,
>>>>> I'm trying to use CGAL's Voronoi Diagrams to subdivide a rectangle
>>>>> region
>>>>> which was composed by input sites and the intersection position with
>>>>> AABB
>>>>> can be obained, and I can render them as GL_POLYGON directly, just like
>>>>> the following demo program. But I found it's a little too complicated to
>>>>> me, so is there any more detailed example ?
>>>>> Thanks.
>>>> Hello,
>> Thanks for your replies.
>> My question is, how to use CGAL to generate a voronoi diagram in a bounded
>> rectangle region, just like this picture
>> http://upload.wikimedia.org/wikipedia/commons/2/20/Coloured_Voronoi_2D.svg
>> I found that there is the Unbound_face_iterator by which I can iterate the
>> all edges, some of them are inner ridges and the others are infinity. How
>> can I calculate the intersection point between the infinity edges and the
>> rectangle's 4 segment ?
>> Thank you again !
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
>Ñî³ÉÁÖ
>Yang Chenglin
- [cgal-discuss] Help for Voronoi, Bo Zhou, 04/06/2010
- Re: [cgal-discuss] Help for Voronoi, 杨成林, 04/07/2010
- Re: [cgal-discuss] Help for Voronoi, Laurent Rineau (GeometryFactory), 04/07/2010
- Re: [cgal-discuss] Help for Voronoi, Bo Zhou, 04/08/2010
- Re: [cgal-discuss] Help for Voronoi, 杨成林, 04/08/2010
- Re: [cgal-discuss] Help for Voronoi, Daniel Duque, 04/09/2010
- Re: [cgal-discuss] Help for Voronoi, Sebastien Loriot (GeometryFactory), 04/09/2010
- Re: [cgal-discuss] Help for Voronoi, Bo Schwarzstein, 04/10/2010
