cgal-discuss - Re: [cgal-discuss] "unable to open file for input" at .exe
  • To:
  • Subject: Re: [cgal-discuss] "unable to open file for input" at .exe
  • Date: Sat, 10 Apr 2010 20:09:00 +0200
On Saturday 10 April 2010 19:25:08 A S wrote:
> Confused. If I am at the following command line:
> C:\CGAL\CGAL-3.6\examples\Alpha_shapes_2\Release>
> ...what do I type?
Either you type:
cd ..
./Release/ex_alpha_shapes_2.exe
(two commands: one to go in the parent directory, and one to launch the
example)
Or, you can copy the directory C:\CGAL\CGAL-3.6\examples\Alpha_shapes_2\data
into C:\CGAL\CGAL-3.6\examples\Alpha_shapes_2\Release and type only:
./ex_alpha_shapes_2.exe
from inside the directory C:\CGAL\CGAL-3.6\examples\Alpha_shapes_2\Release
What is important is that the current working directory contains the
directory
data/, when you launch the example.
Laurent Rineau, PhD
