- To:
- Subject: Re: [cgal-discuss] how to add points to C3t3 for 3D meshing
- Date: Sun, 11 Apr 2010 23:02:55 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=QnUlVMx2v6xv3cpKVlSK2tmiTiiATreKM/BG2Am6Vb3OjPPNRePQuF4nSsz9sZLosl Ix9loXiE0jQHBKziJLj/FxbzuU07yi2FF5aRm/fNaygur3X2sHuyFv/xvMIq/2ndcAyZ a5tsbfy2z9qMUazq4Ke7eowvbhBBLzActD//0=
Hi Laurent,
Thanks for your reply!
Actually I want to initialize the C3t3 as the input for the CGAL::perturb_mesh_3() function.
I tried your method, but it doesn't work. The output .mesh file containts only the points I inserted, no facets or tetrahehra. Any other information I should provide to the C3t3?
Here are my codes:
Polyhedron polyhedron;
Build_mesh<HalfedgeDS> builder(boundary);
polyhedron.delegate(builder);
Mesh_domain domain(polyhedron);
C3t3 c3t3;
for (int i=0; i<tetmesh->nb_vertices(); i++)
// insert points
c3t3.triangulation().insert(Point(tetmesh->vertices_[i].point_[0],tetmesh->vertices_[i].point_[1],tetmesh->vertices_[i].point_[2]));
CGAL::perturb_mesh_3(c3t3, domain, time_limit=300, sliver_bound=10);
std::ofstream medit_file("out_1.mesh");
c3t3.output_to_medit(medit_file);
--zhong
On Sun, Apr 11, 2010 at 8:50 PM, Laurent Rineau (GeometryFactory) <> wrote:
Le Dimanche 11 Avril 2010 14:33:24, Zhonggui Chen a écrit :
Use :> Hi,
> I have some initial points in the domain bounded by a surface mesh. I'd
> like to use the C3t3 to optimize the locations of the points to get a
> better 3D meshing of the domain. How to insert the initial points into
> C3t3?
> Any suggestion would be appreciated!!!
c3t3.triangulation().insert(p)
Laurent Rineau, PhD
- [cgal-discuss] how to add points to C3t3 for 3D meshing, Zhonggui Chen, 04/11/2010
- Re: [cgal-discuss] how to add points to C3t3 for 3D meshing, Laurent Rineau (GeometryFactory), 04/11/2010
- Re: [cgal-discuss] how to add points to C3t3 for 3D meshing, Zhonggui Chen, 04/11/2010
- Re: [cgal-discuss] how to add points to C3t3 for 3D meshing, Laurent Rineau (GeometryFactory), 04/12/2010
