- To:
- Subject: [cgal-discuss] Re: 3D Mesh Generation - polyhedral domain - speed benchmarking
- Date: Sun, 11 Apr 2010 16:25:31 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=bdXsBOiB4kI0N/OkLr+/6naBYBs6WLB2HxqRNHy5/MZziUJdCJLc6pWqqeEsd8R8kO fCNfbxUoDirFmsSBjZ6kdIq7jbcOHfmQyIlm5tjurA39KOqlcbriKWZQB0YBqwRIkyX2 XtS4U9Dj6zpdG2gA1SfGIVY0/9p2xWxt3mv0w=
Ah, never mind. I found it in the documentation.
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Mesh_3/Chapter_main.html#Section_49.4
On Sun, Apr 11, 2010 at 1:20 PM, Ramin H <> wrote:
Hi,
I have used polyhedral domains to create 3D meshes using CGAL 3D mesher.
- I am using Exact_predicates_inexact_constructions_kernel
- I run the code on a AMD Turion64 x2 with 4GB of RAM.
- It's the release version
I was wondering if the following speeds are acceptable if you have bench marked the algorithm yourself
#Facets #Cells Time(sec)
4778 35529 93
18622 278227 581
41600 935242 1699
Thanks,
-Ramin
- [cgal-discuss] 3D Mesh Generation - polyhedral domain - speed benchmarking, Ramin H, 04/11/2010
- [cgal-discuss] Re: 3D Mesh Generation - polyhedral domain - speed benchmarking, Ramin H, 04/11/2010
