- To:
- Subject: [cgal-discuss] Convert Triangulation_2 object to Polyhedron_3
- Date: Wed, 14 Apr 2010 04:31:30 -0800 (PST)
I am trying to find a "fast" way to do the following:
Given an object t of type Triangulation_2 create a Polyhedron_3 which has
the same vertex and edge set
as t.
Looking at the BGL interface for CGAL, I was thinking to use either the
copy_graph command with a custom
VertexCopier function or use the Boost DFS algorithm on the Triangulation
while handling the addition of edges
on the Polyhedron with a customized visitor. But I'm not sure if this is
supposed to work since there doesn't
seem to be some way to create a vertex in your target graph (here: the
Polyhedron) so that you can set any of
the member values of this vertex (e.g. to enter the coordinates of the 3D
point associated with this vertex ).
View this message in context:
http://n4.nabble.com/Convert-Triangulation-2-object-to-Polyhedron-3-tp1839719p1839719.html
- [cgal-discuss] Convert Triangulation_2 object to Polyhedron_3, Costas Tsirogiannis, 04/14/2010
- Re: [cgal-discuss] Convert Triangulation_2 object to Polyhedron_3, Sebastien Loriot (GeometryFactory), 04/14/2010
