Re: [cgal-discuss] Question about method of dealing with the unbounded half-edge in Voronoi_diagram_2
- To: shusen liu <>
- Cc: <>
- Subject: Re: [cgal-discuss] Question about method of dealing with the unbounded half-edge in Voronoi_diagram_2
- Date: Wed, 21 Apr 2010 23:35:53 +0200
Since you can't(or I don't know how) convert unbounded half-edge into
Ray_2, the reasonable solution would be calculate the direction by
yourself using the sites position. But this also turn out to be
difficult to do.
I suppose it would be nice to have a direct way of getting the ray as part of the interface, just as for finite edges/segments. Anyway:
For a Voronoi halfedge you can get the two defining Delaunay vertices in various ways, for instance, by down() and up() or via face()->dual () and opposite()->face()->dual(). Then define a vector between the corresponding points (the one on your side/face first) and obtain the direction of the ray via perpendicular(CGAL::CLOCKWISE).
Another option is to use dt.dual(halfedge->dual()), where dt is the underlying Delaunay triangulation. This returns a CGAL::Object, which can be cast into a ray (if it is a ray) using object_cast (as for intersections...).
If there's a more elegant way to do this, I'd be glad to hear...
hth,
Michael
- [cgal-discuss] Question about method of dealing with the unbounded half-edge in Voronoi_diagram_2, shusen liu, 04/21/2010
- Re: [cgal-discuss] Question about method of dealing with the unbounded half-edge in Voronoi_diagram_2, Michael Hoffmann, 04/21/2010
- RE: [cgal-discuss] Question about method of dealing with the unbounded half-edge in Voronoi_diagram_2, Vu, Khuong, 04/22/2010
- Re: [cgal-discuss] Question about method of dealing with the unbounded half-edge in Voronoi_diagram_2, shusen liu, 04/22/2010
- Re: [cgal-discuss] Question about method of dealing with the unbounded half-edge in Voronoi_diagram_2, Fei (Sophie) Che, 04/22/2010
