cgal-discuss - [cgal-discuss] mark edges with Unique_hash_map
  • To:
  • Subject: [cgal-discuss] mark edges with Unique_hash_map
  • Date: Thu, 22 Apr 2010 17:26:01 +0800
Hi,
I'm trying to mark the edges of an alpha shape using Unique_hash_map.
Part of my codes are:
typedef Alpha_shape_3::Edge Edge;
typedef CGAL::Unique_hash_map<Edge,int> UhmEdge2int; << this line is ok
list<Weighted_point> lwp;
Alpha_shape_3 as(lwp.begin(), lwp.end(), 0, Alpha_shape_3::GENERAL);
Alpha_shape_3::Finite_edges_iterator eit;
UhmEdge2int uhmedge2int;
for (eit = as.finite_edges_begin(); eit != as.finite_edges_end();eit++)
if(as.classify(*eit,0)==Alpha_shape_3::REGULAR)
uhmedge2int[eit]=1; << there is an error with this line.
error: no
match for ‘operator[]’ in ‘uhmedge2int[eit]’
I also tried "uhmedge2int[*eit]" and it doesn't work.
But I thought I'm using it as the same way like in the example 51.4.2.
In example 51.4.2: "Example with edges marked as non-removable" a class
was build like this:
class Constrains_map : public boost::put_get_helper<bool,Constrains_map>
public:
typedef boost::readable_property_map_tag category;
typedef bool value_type;
typedef bool reference;
typedef boost::graph_traits<Surface const>::edge_descriptor key_type;
Constrains_map() : mConstrains(false) {}
reference operator[](key_type const& e) const { return e->is_border() ||
is_constrained(e) ; }
void set_is_constrained ( key_type const& e, bool is ) {
mConstrains[e]=is; }
bool is_constrained( key_type const& e ) const { return
mConstrains.is_defined(e) ? mConstrains[e] : false ; }
private:
CGAL::Unique_hash_map<key_type,bool> mConstrains ;
Can anyone tell me what's wrong with my codes?
Best regards,
Lin
Center of Computational and Systems Biology,
Institute of Biophysics, CAS.
15 Datun Road, Chaoyang District
Beijing, 100101
P.R.China
