- To:
- Subject: Re: [cgal-discuss] indices of faces, halfedges, vertices
- Date: Tue, 27 Apr 2010 11:49:33 +0200
wrote:
I have a polyhedron P.Is something like this a correct solution for your problem?
And I want to associate to each face an index : the distance from
P->facets_begin() to the iterator pointing to the face (for example).
Now, given a halfedge h, I would like to know the number of h.facets().
I tried std::distance(P.facets_begin(), h.facets()) but it doesn't work
since one is an iterator and the other a handle.
Is there a simple way to do that ?
unsigned i=0
for (Polyhedron::Facet_iterator it=P.facets_begin();it!=P.facets_end();++it){
it->id()=i++;
S.
- [cgal-discuss] indices of faces, halfedges, vertices, cc . ld, 04/27/2010
- Re: [cgal-discuss] indices of faces, halfedges, vertices, Sebastien Loriot (GeometryFactory), 04/27/2010
- Re: [cgal-discuss] indices of faces, halfedges, vertices, cc . ld, 04/27/2010
- Re: [cgal-discuss] indices of faces, halfedges, vertices, Mohamed Yousef, 04/27/2010
- Re: [cgal-discuss] indices of faces, halfedges, vertices, Sebastien Loriot (GeometryFactory), 04/28/2010
- Re: [cgal-discuss] indices of faces, halfedges, vertices, Mohamed Yousef, 04/29/2010
