cgal-discuss - [cgal-discuss] A newbie question: Mesh_complex_3_in_triangulation & VRML stream
  • To:
  • Subject: [cgal-discuss] A newbie question: Mesh_complex_3_in_triangulation & VRML stream
  • Date: Mon, 17 May 2010 15:45:36 +0300
Hi!
I am using the code from chapter "47.3.2 Mesh Generation From a Polyhedral
Domain", the elephant case to generate different meshes from [classified]
point
cloud.
The problem that I am currently facing is some type mismatch for tetrahedron
struct K: public CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef CGAL::Mesh_3::Robust_intersection_traits_3<K> Geom_traits;
typedef CGAL::Polyhedron_3<Geom_traits> Polyhedron;
typedef Polyhedron::Point_3 Point;
typedef Polyhedron::HalfedgeDS HalfedgeDS;
typedef CGAL::Polyhedral_mesh_domain_3<Polyhedron, Geom_traits> Mesh_domain;
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3;
std::ofstream vrml_file( "mesh-1-out.wrl" );
CGAL::VRML_2_ostream vrml_stream( vrml_file );
for( C3t3::Facet_iterator f = c3t3.facets_begin();
f != c3t3.facets_end(); ++f )
C3t3::Triangulation::Triangle t =
c3t3.triangulation().triangle( *f );
vrml_stream << t;
for( C3t3::Cell_iterator c = c3t3.cells_begin();
c != c3t3.cells_end(); ++c )
// This line won't compile...
C3t3::Triangulation::Tetrahedron t =
c3t3.triangulation().tetrahedron( *c );
// This compiles & links
///C3t3::Triangulation::Tetrahedron t;
vrml_stream << t;
vrml_stream.close();
Everything seems to be okay, but for some reason I got following error (see
end
of mail), which looks like that tetrahedron other than
C3t3::Triangulation::Tetrahedron is returned. The triangle part works fine, so
what I am doing wrong?
CGAL version is 3.5.1-1 (Ubuntu 10.04) and GCC is 4.4.3-4ubuntu5.
Lehtonen, Matti
Researcher, head programmer - Helsinki Institute for Information Technology
HIIT
http://www.hiit.fi/
The error message by GCC:
triangulator.cpp:218: error: no matching function for call to
‘CGAL::Regular_triangulation_3<CGAL::Robust_weighted_circumcenter_filtered_traits_3<CGAL::Regular_triangulation_filtered_traits_3<CGAL::Mesh_3::Robust_intersection_traits_3<K>
CGAL::Triangulation_data_structure_3<CGAL::Mesh_vertex_base_3<CGAL::Robust_weighted_circumcenter_filtered_traits_3<CGAL::Regular_triangulation_filtered_traits_3<CGAL::Mesh_3::Robust_intersection_traits_3<K>
CGAL::Polyhedral_mesh_domain_3<CGAL::Polyhedron_3<CGAL::Mesh_3::Robust_intersection_traits_3<K>,
CGAL::Polyhedron_items_3, CGAL::HalfedgeDS_default, std::allocator<int> >,
CGAL::Triangle_accessor_3<CGAL::Polyhedron_3<CGAL::Mesh_3::Robust_intersection_traits_3<K>,
CGAL::Mesh_3::Robust_intersection_traits_3<K> > >,
CGAL::Triangulation_vertex_base_3<CGAL::Robust_weighted_circumcenter_filtered_traits_3<CGAL::Regular_triangulation_filtered_traits_3<CGAL::Mesh_3::Robust_intersection_traits_3<K>
> >, CGAL::Triangulation_ds_vertex_base_3<void> > >,
CGAL::Mesh_cell_base_3<CGAL::Robust_weighted_circumcenter_filtered_traits_3<CGAL::Regular_triangulation_filtered_traits_3<CGAL::Mesh_3::Robust_intersection_traits_3<K>
CGAL::Regular_triangulation_cell_base_3<CGAL::Robust_weighted_circumcenter_filtered_traits_3<CGAL::Regular_triangulation_filtered_traits_3<CGAL::Mesh_3::Robust_intersection_traits_3<K>
CGAL::Triangulation_cell_base_3<CGAL::Robust_weighted_circumcenter_filtered_traits_3<CGAL::Regular_triangulation_filtered_traits_3<CGAL::Mesh_3::Robust_intersection_traits_3<K>
> >, CGAL::Triangulation_ds_cell_base_3<void> >,
std::list<CGAL::Weighted_point<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >, double>,
std::allocator<CGAL::Weighted_point<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >, double> > > > > >
>::tetrahedron(CGAL::Mesh_cell_base_3<CGAL::Robust_weighted_circumcenter_filtered_traits_3<CGAL::Regular_triangulation_filtered_traits_3<CGAL::Mesh_3::Robust_intersection_traits_3<K>
CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Mesh_vertex_base_3<CGAL::Robust_weighted_circumcenter_filtered_traits_3<CGAL::Regular_triangulation_filtered_traits_3<CGAL::Mesh_3::Robust_intersection_traits_3<K>
> >, double>,
> >, double> > > > > > > >,
> >, double>,
> >, double> > > > >&)’
/usr/include/CGAL/Triangulation_3.h:387: note: candidates are: typename
GT::Tetrahedron_3 CGAL::Triangulation_3<GT, Tds>::tetrahedron(typename
Tds::Cell_handle) const [with GT =
> >, Tds =
> >, double>,
> >, double> > > > > >]
Life is complex. It has real and imaginary parts.
