- To:
- Subject: Re: [cgal-discuss] Order in AABB tree
- Date: Wed, 19 May 2010 11:53:29 +0200
wrote:
Hi,
I was wondering if it is possible to set an order evaluating intersections
by means of the AABB Tree algorithm. In the documentation I find that "No
particular order is guaranteed over the tree traversal, such that, e.g,
the primitive returned is not necessarily the closest from the source
point of a ray query". The algorithm follows the given order of the input
primitives calculating intersections (for example a list of triangles
composing tetrahedra)? Conversely I would like to follow a ray crossing a
3D object represented as a 3D complex ( for example a tetrahedron mesh in
3D mesh generation) and I need to control two consecutive ("couples" of
closest intersected points) intersections and their relative distance.
Thank in advance!
Hi,
I'm not sure to fully understand your concern but maybe this could help. There is a function which allows you to retrieve all the intersections between a ray and the primitives contained in the tree (named all_intersections).
Then you should be able to sort those intersection points along the ray to get what you want.
Concerning the order there is no way to specify it, it follows the internal tree structure.
Regards,
Stéphane.
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
- [cgal-discuss] Order in AABB tree, cecilia, 05/12/2010
- Re: [cgal-discuss] Order in AABB tree, Stephane Tayeb, 05/19/2010
