Re: [cgal-discuss] Splitting a polyhedron halfedge and fixing the point of the new vertex
- To:
- Subject: Re: [cgal-discuss] Splitting a polyhedron halfedge and fixing the point of the new vertex
- Date: Thu, 20 May 2010 16:52:28 +0200
Costas Tsirogiannis wrote:
Hello Costas,
Greetings,
I'm running an algorithm on a Polyhedron_3 object. At some point during the execution
the algorithm decides to split a (half)edge h into two pieces.
Consider the vertex v that is created on (what used to be) the interior of h.
I want the algorithm then to fix the coordinates of v->point() to some specific ones.
How can this be done? There is the spilt_edge member function of the polyhedron but
this actually makes v to be the copy of some pre-existing vertex.
The polyhedron vertex class does not have either any "set_point()" member function.
Can I do something with the de-constified version of vertex->point()?
I think vertex->point()=Your_new_point; should work.
S.
thanks in advance
Constantinos
- [cgal-discuss] Splitting a polyhedron halfedge and fixing the point of the new vertex, Costas Tsirogiannis, 05/20/2010
- Re: [cgal-discuss] Splitting a polyhedron halfedge and fixing the point of the new vertex, Sebastien Loriot (GeometryFactory), 05/20/2010
