- To:
- Subject: [cgal-discuss] Re: How to correct these conflicts between CGAL with MSVC8
- Date: Thu, 20 May 2010 20:19:48 -0700 (PDT)
Hi, Laurent Rineau, Andreas Fabri,
Thank you very much for your instructions.
After I cancel the line of MathFix.h: #define pow(x, y) wtf_pow(x, y) and
re-compile, there are no 'std::wtf_pow' errors like I described in the first
message.
Now I change to use CGAL 3.6, the latest release CGAL. When I try to build
the application routine based on CGAL3.6, it needs CGAL/compiler_config.h
and cl_1400.h, I copy CGAL/compiler_config.h and cl_1400.h from CGAL 3.3.1
to CGAL 3.6. Is it correct?
However, when I try to compile it, there are 174 errors about CGAL as
following:
CGAL-3.6\include\CGAL/Quotient.h(129) : error C2143: syntax error : missing
')' before '&&'
1> CGAL-3.6\include\CGAL/Quotient.h(190) : see reference to class
template instantiation 'CGAL::Quotient<NT_>' being compiled
1>CGAL-3.6\include\CGAL/Quotient.h(129) : error C2143: syntax error :
missing ';' before '&&'
1>CGAL-3.6\include\CGAL/Quotient.h(129) : error C2238: unexpected token(s)
preceding ';'
1>CGAL-3.6\include\CGAL/Quotient.h(129) : error C2988: unrecognizable
template declaration/definition
1>CGAL-3.6\include\CGAL/Quotient.h(129) : error C2059: syntax error : '&&'
1>CGAL-3.6\include\CGAL/Quotient.h(129) : error C2059: syntax error : ')'
1>CGAL-3.6\include\CGAL/Quotient.h(134) : error C2334: unexpected token(s)
preceding ':'; skipping apparent function body
1>CGAL-3.6\include\CGAL/Quotient.h(136) : error C2143: syntax error :
missing ')' before '&&'
1>CGAL-3.6\include\CGAL/Quotient.h(136) : error C2059: syntax error : ')'
1>CGAL-3.6\include\CGAL/Quotient.h(136) : error C2334: unexpected token(s)
1>CGAL-3.6\include\CGAL/Quotient.h(233) : error C2244:
'CGAL::Quotient<NT_>::operator +=' : unable to match function definition to
an existing declaration
1> definition
1> 'CGAL::Quotient<NT_> &CGAL::Quotient<NT_>::operator +=(const
CGAL::Quotient<NT_> &)'
1> existing declarations
First_if_different<double,NT_>::Type &)'
First_if_different<int,RT_>::Type &)'
1> 'CGAL::Quotient<NT_> &CGAL::Quotient<NT_>::operator +=(const NT_
1> CGAL-3.6\include\CGAL/Handle_for_virtual.h(104) : error C2143: syntax
error : missing ')' before '&&'
1>CGAL-3.6\include\CGAL/Handle_for_virtual.h(175) : see reference to class
template instantiation 'CGAL::Handle_for_virtual<RefCounted>' being compiled
1>CGAL-3.6\include\CGAL/Handle_for_virtual.h(104) : error C2143: syntax
error : missing ';' before '&&'
1>CGAL-3.6\include\CGAL/Handle_for_virtual.h(104) : error C2059: syntax
error : ')'
1>CGAL-3.6\include\CGAL/Handle_for_virtual.h(105) : error C2334: unexpected
token(s) preceding '{'; skipping apparent function body
1>CGAL-3.6\include\CGAL/Object.h(47) : error C2143: syntax error : missing
')' before '&&'
1>CGAL-3.6\include\CGAL/Object.h(66) : see reference to class template
instantiation 'CGAL::Wrapper<T>' being compiled
';' before '&&'
I am new to C++ and CGAL, could you please instruct me to solve these
problems?
Thank you very much!
Best wishes,
John Hans
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-correct-these-conflicts-between-CGAL-with-MSVC8-tp2223982p2225578.html
- [cgal-discuss] How to correct these conflicts between CGAL with MSVC8, JohnHans, 05/20/2010
- Re: [cgal-discuss] How to correct these conflicts between CGAL with MSVC8, Sebastien Loriot (GeometryFactory), 05/20/2010
- Re: [cgal-discuss] How to correct these conflicts between CGAL with MSVC8, Andreas Fabri, 05/20/2010
- [cgal-discuss] Re: How to correct these conflicts between CGAL with MSVC8, JohnHans, 05/20/2010
- Re: [cgal-discuss] Re: How to correct these conflicts between CGAL with MSVC8, Andreas Fabri, 05/20/2010
- Re: [cgal-discuss] Re: How to correct these conflicts between CGAL with MSVC8, Laurent Rineau (GeometryFactory), 05/20/2010
- [cgal-discuss] Re: How to correct these conflicts between CGAL with MSVC8, JohnHans, 05/21/2010
- Re: [cgal-discuss] Re: How to correct these conflicts between CGAL with MSVC8, Andreas Fabri, 05/21/2010
