cgal-discuss - Re: [cgal-discuss] meshing 2d
  • To:
  • Subject: Re: [cgal-discuss] meshing 2d
  • Date: Tue, 25 May 2010 10:54:30 +0200
On 24/05/2010 20:12, Hansjoerg Seybold wrote:
hello,
I am trying to use the member function cdt.incident_constraints(va,done);
I am not sure what you mean with "done".
The signature of the function is
OutputIterator cdt.incicent_constraints(Vertex_handle va,
OutputIterator out);
std::list<Edge> edges;
cdt.incident_constraints(std::back_inserter(edges));
Now you traverse the edge list the usual way.
If instead of storing the edges you could write your
own outout itertor class that does something on the
fly, whenever the next edge gets assigned to it.
Best regards,
andreas
but i am not sure if i use the EdgeItOutput correctly.
I first create a list with the iterators
insert_iterator<list<Edge> > ei,done;
and later iterate over the content of the list with list<Edge>::iterator
eit;
This looks a bit wired to me that i have to use a list where i store the
edges first.
Is there an example using these things in the CGAL demo/examples?
Thanks a lot
hj
On Sun, May 23, 2010 at 8:45 AM, Hansjoerg Seybold
<mailto:>>
wrote:
Hi,
thanks a lot for the hints.
I had a deeper search in the reference manual and found the linewalk
function which could be used to walk along the constraint edges of
the PGLS.
The question is if the linewalk is save with respect to exact
predictions.
Otherwise i can also search along the constraint edges wwith
circulators until i reach the endpoint of the constraint PGLS edge.
thanks
hj
On Tue, May 18, 2010 at 5:32 PM, Mariette Yvinec
<mailto:>>
thanks for the answer, but i dont understand how i should mark
the cells.
assume i have an internal segment edge of the PLGS, which is
devided into 3 parts by the insetion of 2 gabriel points.
There are mesh cells
left and right to the PLGS edge.
How do i have to iterate the determine the cells which are
left/right of the edge?
or inide/outside of a polygon for example inside/outside of the
triangular region in example 45.4
Can i mark the cells during the mesh generation to keep track
on to which region they belong to?
thanks a lot
hj
You may mark the cells once the mesh is generated.
There is an example of such a marking in the file:
demo/Triangultion_2/Constrained_Delaunay_triangulation_2.cpp
On Mon, May 17, 2010 at 2:38 PM, Mariette Yvinec
<mailto:>>
wrote:
A better way, may be to mark the cells
with some indexes of the subdomain they belong to.
Using a propagation algorithm through cell adjacency
it is easy to mark the cells.
Then knowing on which boundary
are the edges is straightforward.
The main advantage is to avoid using
geometric tests like is_colinear()
which might yield a false result if you use floating point
computations
and is costly when using an EPIC Kernel.
hello,
thanks a lot. This would help to determine weather
boundary or not.
For a fem mesh i further have to know on which boundary the
nodes are to apply the appropriate boundary conditions in
the calculations. Also for internal boundary conditions
the is_in_domain()
is not sufficient.
I was thinking to check all vvertices with all edges of
the PLGS with the basic functions
are_ordered_along line() or is_colinear() because i could
not find a better
point location method which returns the edge of the PLGS
for a given
vertex. Please let me know if you have a better
suggestion for me.
best hj
On Mon, May 17, 2010 at 10:51 AM, Mariette Yvinec
<mailto:>>
wrote:
You may identify the boundary edges as edges incident
to a single face that is in the doamain.
This can be tested using the is_in_domain() member
function
of the facet.
Hello,
i could not find a function /flag in the mesher that
identifies the boundary
edges, meaning edges that are part of the initial PLGS.
I saw that for a 3D mesh a IS_BOUNDARY type exists.
but for 2d meshes i could not find an equivalence.
Do i have to check the boundary query by hand using
geometric queries for the vertex points of the mesh
and the edges of the original PLGS?
thanks a lot
hansjoerg
On Thu, Apr 22, 2010 at 3:31 PM, Hansjoerg Seybold
<mailto:>>
wrote:
Thanks for the reply.
the mesh_domain thus is a simple triangulation
object.
One question remains: how do i identify if the
newly inserted vertices (edge) is lying on the
original boundary
triangulation identify the boudnary of the mesh
domain
thanks
On Thu, Apr 22, 2010 at 2:01 PM, Ramin H
<mailto:>>
wrote:
Look here:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html
/typedef Tds::Face_iterator /
/All_faces_iterator; / iterator over all
faces.
/ typedef Tds::Edge_iterator /
/All_edges_iterator; / iterator over all edges
/ typedef Tds::Vertex_iterator /
/All_vertices_iterator; / iterator over all
vertices
-Ramin
On Thu, Apr 22, 2010 at 5:44 AM, Hansjoerg
Seybold
<mailto:>>
wrote:
hello,
I am trying to make a simple 2D mesher
for a FEM code using the cgal meshing
capabilities.
I experimenteeeed with the meshing
examples and demos. What i could not
find in the
documentation and the examples is
How can i iterate through the mesh,
Faces, Vertices, Edges?
Is there a method to determine if a
edge/vertex lies on a boundary (meaning
part of the CDT which is used as input
for the mesher?
Are there default io streams for the meshs?
It would be nice if anybody has some
suggestions references for
documentation etc on this topic.
Thanks a lot
best hansjoerg
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
Mariette Yvinec
Mariette Yvinec
