- To:
- Subject: Re: [cgal-discuss] Gmpz constructed from non-integer double value
- Date: Thu, 3 Jun 2010 12:38:54 +0200 (CEST)
- Organization: Institut fuer Werkstoffe TU Braunschweig
Perhaps you could use Gmpq instead, that easily allows for arbitrary
rationals.
Thanks, what should I do for general floats?
----- Original Message -----
To:
Sent: Thursday, June 03, 2010 4:41 PM
Jianfei Liu wrote:--
I am reading a simple .off file and traslate it from polyhedron to Nef
polyhedron, but failed with an error:Gmpz constructed from non-integer double
value.
The error message says it all: 0.256 is not an integer, whereas Gmpz is an
integer-type. You cannot convert arbitrary floats to this type. Only floats
representing integral values can be converted.
I noticed somebody says it is a bug for older CGAL, however it seems still
existing for the newest version 3.6.
OFF
4 4 0
0 0 0.256
1 0 0
0 1 0
0 0 1
3 0 2 1
3 0 1 3
3 0 3 2
3 1 2 3
The problem is caused by 0.256 in the above file.
Multiply your coordinates by 1000 ;-)
-- Stefan
Priv.-Doz. Dr. Martin Bäker
Institut für Werkstoffe
Technische Universität Braunschweig
Langer Kamp 8
38106 Braunschweig
Germany
Tel.: 00-49-531-391-3073
Fax 00-49-531-391-3058
- [cgal-discuss] unique function, cecilia, 06/01/2010
- <Possible follow-up(s)>
- [cgal-discuss] Gmpz constructed from non-integer double value, Jianfei Liu, 06/02/2010
- Re: [cgal-discuss] Gmpz constructed from non-integer double value, Stefan Schirra, 06/03/2010
- Re: [cgal-discuss] Gmpz constructed from non-integer double value, Jianfei Liu, 06/03/2010
- Re: [cgal-discuss] Gmpz constructed from non-integer double value, Martin Baeker, 06/03/2010
- [cgal-discuss] Re: Gmpz constructed from non-integer double value, Jianfei Liu, 06/03/2010
