cgal-discuss - Re: [cgal-discuss] How to prevent "Mesh_3 ERROR: A facet is not in conflict with its refinement point!" happening?
  • To:
  • Subject: Re: [cgal-discuss] How to prevent "Mesh_3 ERROR: A facet is not in conflict with its refinement point!" happening?
  • Date: Thu, 03 Jun 2010 17:57:22 +0200
Lehtonen, Matti/HIIT wrote:
Hi!
When I am creating a mesh in Polyhedral mesh domain for later refinement, I
got
following error always:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
File: /usr/include/CGAL/Mesh_3/Refine_facets_3.h
Line: 526
Explanation: Mesh_3 ERROR: A facet is not in conflict with its refinement
point!
Debugging informations:
Facet: (0x25c9530, 2) = (-39.0758 -56.2995 12.8917 0, 130.77 133.294 16.7889
0, 10.7582 -6.93443 13.8584 0)
Dual: (-9.03193e+16 2.97869e+17 -1.05546e+19 0, 2.03556e+16 -6.71319e+16
2.37873e+18 0)
Refinement point: 115.949 138.899 17.0739 0
What does it actually means and is there anything I could prevent from
happening, like carefully selecting facet and cell criterias?
thx,
Matti Lehtonen
Researcher, head programmer - Helsinki Institute for Information Technology
HIIT
http://www.hiit.fi/
Hi,
This error means that the point which is inserted in the triangulation to refine a 'bad' facet does not destroy this facet.
Such an error often happen in those two cases:
1- the dual is wrongly computed
2- the intersection between the dual and the surface is wrongly computed
'1-' should not be a problem if you are using:
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
'2-' depends on the Domain (oracle) your are using, and eventually on your input data.
It's hard to tell you about a 'generic' way to solve such an issue. Maybe it could be easier if you provide more informations about your oracle and data.
I hope it helps.
Regards,
Stéphane.
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
