cgal-discuss - Re: [cgal-discuss] Re: How to correct these conflicts between CGAL with MSVC8
  • To:
  • Subject: Re: [cgal-discuss] Re: How to correct these conflicts between CGAL with MSVC8
  • Date: Sat, 5 Jun 2010 11:40:24 +0200
Le samedi 05 juin 2010 07:33:37, JohnHans a écrit :
> Hi,
> Now I have built the latest CGAL 3.6 based on Qt4.5.3 and Boost 1.41.
> However, which include file is about identifier lroundf, round?
> And I also cannot find the include file: 'unistd.h'.
> Thank you very much!
lroundf is standardized in C99 in <math.h>, but it is not in C++98. It will
be
in the future norm C++0x in <cmath>.
As your compiler does not have it for the moment, you could write your own
version: that is what you were doing with MathFix.h. But you incorrectly used
macros conflicting with other header files. You can also use a cross-platform
implementation of that. There is one in Boost.Math: there is one template
version lround<T>, and another one implementing really functions of C++ TR1
and C++0x, with lroundf among them.
http://www.boost.org/doc/libs/1_43_0/libs/math/doc/sf_and_dist/html/math_toolkit/main_overview/tr1.html
http://www.boost.org/doc/libs/1_43_0/libs/math/doc/sf_and_dist/html/math_toolkit/utils/rounding/round.html
If you want to use the Boos.Math functions, please read the manual carefully:
be sure to link with the right Boost libraries if you use Boost.Math
implementation of TR1, and be careful of the namespaces that contains the
identifiers you want to use.
Laurent Rineau, PhD
