cgal-discuss - Re: [cgal-discuss] nearest_point_3 in AABB tree for tetrahedrons
  • To:
  • Subject: Re: [cgal-discuss] nearest_point_3 in AABB tree for tetrahedrons
  • Date: Tue, 08 Jun 2010 00:04:22 +0200
Hi,
Thanks for the fast reply!
Den 07. juni 2010 22:28, skrev Pierre Alliez:
hi Andre,
as soon as you add the proper predicates and constructions to your CGAL
this is going to work.
for your case you have to add nearest_point_tetrahedron_3 and
Tetrahedron_3_Sphere_3_do_intersect.h (see example in
CGAL/include/CGAL/AABB_intersections).
Yes, I have already had a look at it, but (as a non computational geometer) was unsure about the effort to implement it.
as CGAL is an open source project we would happy if you can then
contribute these functions to CGAL.
Ok, I will have a look at it. Probably
./internal/AABB_tree/nearest_point_triangle_3.h
is the best guiding example?
BTW during the customization of the AABB_tree class for the FEM library DOLFIN I added (locally within the source distribution) some code to perform
-tetrahedron-tetrahedron intersection detection
-tetrahedron-bbox intersection intersection detection
and made
-Point-<Whatever> intersections available via do_intersect kernel function such that it can be also used for example in the AABB tree.
Maybe there is an interest to have a look at it some day whether it worth to be considered?
best regards,
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee
Project-team GEOMETRICA
http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
Le 07/06/2010 22:00, Andre Massing a écrit :
Hi!
At the moment the closest_point function in the AABB_tree class
template works only for segments and triangles.
Are there any plans in the near future for adding support for
tetrahedrons as well?
Kind regards,
Andre Massing
