cgal-discuss - [cgal-discuss] Proper way to convert C3T3 (3D mesh) to HDS?
  • To:
  • Cc: Matti Lehtonen <>
  • Subject: [cgal-discuss] Proper way to convert C3T3 (3D mesh) to HDS?
  • Date: Sat, 19 Jun 2010 17:43:50 +0300
Hi!
I have written a new mesh domain (labeled point set). How ever, it generates
invalid meshes (some triangles won't satisfy criterias like minimum angle of
30
degrees and triangles are kind of 'soap'). I believe that the wrapper function
or CGAL::Mesh_3::Labeled_mesh_domain_3 aren't faulty, but the conversion from
C3T3 to HDS fails for some reason. Any help is more than welcome.
Function wrapper at CGAL::Point_set_to_labeled_function_wrapper (yes, I am
planning to donate this, if this works):
return_type
operator()
Point_3 const & p,
bool const = true
const
// Bounding box of kd -tree
TreeBbox const & bbox = _set.bounding_box();
if( ( bbox.min_coord( 0 ) > p.x() ) || ( p.x() > bbox.max_coord( 0 ) ) ||
( bbox.min_coord( 1 ) > p.y() ) || ( p.y() > bbox.max_coord( 1 ) ) ||
( bbox.min_coord( 2 ) > p.z() ) || ( p.z() > bbox.max_coord( 2 ) ) )
// Outside of domain
return CGAL::NEVER_CLASSIFIED;
// Initialize the search structure, and search nearest point
Query_item const & q = Query_item( Point_with_normal( p ) );
Neighbor_search search( _set, q );
Labeled_point const & n1 = search.begin()->first;
double const projectionLengthOnNormal = ( p.x() - n1.position().x() ) *
n1.normal().x()
+ ( p.y() - n1.position().y() ) * n1.normal().y()
+ ( p.z() - n1.position().z() ) * n1.normal().z();
if( projectionLengthOnNormal > 0.0 )
// Assumption: points are from surface with well defined normals
// (pointing [mostly] up) and above of surface is AIR -domain
return CGAL::ARTIFICAL_DOMAIN_AIR;
else
return n1.label();
I believe that actually the C3T3 to HDS conversion fails for some reason,
I just cannot Identify why ...
typedef struct BuilderInfo
size_t number_of_faces;
PointIndex index;
HalfedgeDS * hds;
Pib * builder;
BuilderInfo()
: number_of_faces( 0 ), index( PointIndex() ), hds( NULL ), builder( NULL )
~BuilderInfo()
delete builder;
delete hds;
} BuilderInfo;
typedef class Mesh_domain : public
CGAL::Labeled_point_set_mesh_domain_3<PointSet,TreeBoundingBox,
Neighbor_search,Kernel> {...} Mesh_domain;
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3;
typedef CGAL::Polyhedron_incremental_builder_3<HalfedgeDS> Pib;
static
void
create_polyhedrons
PolyhedronList & polyhedrons,
C3t3 const * const c3t3
typedef std::map<SurfaceKeys,BuilderInfo*> Mapping;
Mapping mapping;
// GO thru all 2D faces: collect face and vertice counts
std::cerr << "*** 2D face count and index vertices ***" << std::endl;
std::cerr << "* faces - " << c3t3->number_of_facets() << std::endl;
std::cerr << "* vertices - " << c3t3->number_of_vertices() << std::endl;
for( C3t3::Facet_iterator fi = c3t3->facets_begin();
fi != c3t3->facets_end(); ++fi )
C3t3::Facet const & f = *fi;
C3t3::Surface_index const & si = c3t3->surface_index( f );
C3t3::Cell_handle const & ch = f.first;
C3t3::Subdomain_index const & sdi = c3t3->subdomain_index( ch );
if( ( sdi == CGAL::NEVER_CLASSIFIED ) ||
( si.first == CGAL::NEVER_CLASSIFIED ) ||
( si.second == CGAL::NEVER_CLASSIFIED ) )
// Ignore domains and surfaces related to non-classified volume
continue;
// Select Polyhedron incremental builder
SurfaceKeys k( sdi, si );
if( mapping.find( k ) == mapping.end() )
mapping.insert( std::make_pair( k, new BuilderInfo() ) );
BuilderInfo * bi = mapping[ k ];
// Count faces
bi->number_of_faces++;
// Index points and count vertices
C3t3::Triangulation::Cell const & c = *ch;
for( int vi = 0; vi < 4; ++vi )
if( vi == f.second )
continue;
C3t3::Vertex_handle const & vh = c.vertex( vi );
C3t3::Triangulation::Vertex const & v = *vh;
Point const & p = v.point();
if( bi->index.find( p ) == bi->index.end() )
///std::cerr << "* p - " << p.x() << " " << p.y() << " " << p.z() <<
std::endl;
size_t const counter = bi->index.size();
bi->index[ p ] = counter;
// GO thru all 2D surfaces: add vertices for surfaces
std::cerr << "*** Add vertices to surface ***" << std::endl;
for( Mapping::iterator ki = mapping.begin(); ki != mapping.end(); ++ki )
SurfaceKeys const & k = ki->first;
C3t3::Subdomain_index const & sdi = k.first;
C3t3::Surface_index const & si = k.second;
std::cerr << "* subdomain index - " << sdi << std::endl;
std::cerr << "* surface index - pair<" << si.first << "," << si.second <<
">" << std::endl;
BuilderInfo * bi = ki->second;
std::cerr << "* faces - " << bi->number_of_faces << std::endl;
std::cerr << "* vertices - " << bi->index.size() << std::endl;
bi->hds = new HalfedgeDS( bi->index.size(), 3 * bi->number_of_faces,
bi->number_of_faces );
bi->builder = new Pib( *( bi->hds ) /*, true */ );
bi->builder->begin_surface( bi->index.size(), bi->number_of_faces,
3 * bi->number_of_faces );
for( PointIndex::iterator pi = bi->index.begin();
pi != bi->index.end(); ++pi )
Point const & p = pi->first;
bi->builder->add_vertex( p );
// GO thru all 2D faces: add faces to surfaces
std::cerr << "*** Add 2D faces to surfaces ***" << std::endl;
C3t3::Surface_index const si = c3t3->surface_index( f );
C3t3::Subdomain_index const sdi = c3t3->subdomain_index( ch );
continue;
///std::cerr << "* face - " << sdi << ", pair<"<< si.first << "," <<
si.second << ">" << std::endl;
bi->builder->begin_facet();
C3t3::Triangulation::Triangle const & t =
c3t3->triangulation().triangle( f
int v_index = 0;
for( size_t i = 0; i < 3;
++i, v_index = c3t3->triangulation().ccw( v_index ) )
Point const & p = t.vertex( v_index );
size_t const idx = bi->index[ p ];
///std::cerr << "* vertex - " << idx << std::endl;
bi->builder->add_vertex_to_facet( idx );
bi->builder->end_facet();
// Close all surfaces
std::cerr << "*** Close all surfaces ***" << std::endl;
std::cerr << "Surface:" << std::endl;
std::cerr << "* surface - " << sdi << ", pair<"<< si.first << "," <<
bi->builder->end_surface();
std::cerr << "* halfedges - " << bi->hds->size_of_halfedges() <<
std::endl;
std::cerr << "* vertices - " << bi->hds->size_of_vertices() << std::endl;
std::cerr << "Remove unconnected vertices:" << std::endl;
(void) bi->builder->remove_unconnected_vertices();
std::endl;
// Fill Polyhedron
std::cerr << "Polyhedron:" << std::endl;
SurfacePolyhedron SP;
SP.first = k;
Polyhedron & P = SP.second;
Build_3D_Mesh_triangulation<HalfedgeDS> triangulation( *( bi->hds ) );
P.delegate( triangulation );
std::cerr << "* facets - " << P.size_of_facets() << std::endl;
std::cerr << "* halfedges - " << P.size_of_halfedges() << std::endl;
std::cerr << "* vertices - " << P.size_of_vertices() << std::endl;
std::cerr << "* is_valid - " << ( P.is_valid( false ) ? "YES" : "NO" ) <<
std::endl;
std::cerr << "Border of polyhedron:" << std::endl;
P.normalize_border();
std::cerr << "* border halfedges - " << P.size_of_border_halfedges() <<
std::endl;
std::cerr << "* border edges - " << P.size_of_border_edges() <<
std::endl;
std::cerr << "* border is_valid - " << ( P.normalized_border_is_valid() ?
"YES" : "NO" ) << std::endl;
// Return Polyhedron
if( !P.empty() )
polyhedrons.push_back( SP );
std::cerr << "*** Polyhedron list ***" << std::endl;
std::cerr << "* polyhedrons - " << polyhedrons.size() << std::endl;
Thx for any help or suggestions
Lehtonen, Matti
Researcher, head programmer - Helsinki Institute for Information Technology
HIIT
http://www.hiit.fi/
Life is complex. It has real and imaginary parts.
