- To:
- Subject: Re: [cgal-discuss] Where to start finding Approximate Nearest Neighbor?
- Date: Wed, 23 Jun 2010 16:22:59 +0200
Bo Schwarzstein wrote:
Try STANN or just ANN is faster than CGAL's solution.Sorry to re-open this old thread but I just run a benchmark, and
on tested examples I found that CGAL Orthogonal_nearest_neighbor is
faster than STANN and ANN.
Do you have examples where you found that this is not true?
S.
2010/4/2 Anthony Palomba < <mailto:>>
Awesome thanks!
-ap
On Thu, Apr 1, 2010 at 11:00 AM, Andreas Fabri
<mailto:>>
wrote:
The best way to start is going into the package overview
http://www.cgal.org/Manual/last/doc_html/cgal_manual/packages.html
click on Spatial Searching and Sorting
which brings you here:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/packages.html#part_XIII
and click on "User Manual" of the Chapter "dD Spatial Searching"
There are examples which you also find in the distribution
andreas
On 01/04/2010 17:48, Anthony Palomba wrote:
I am interested in using CGAL to explore finding the
approximate nearest
neighbor
of a point with in a system of points.
What interface should I start looking at?
Thanks,
Anthony
-- You are currently subscribed to cgal-discuss.
- Re: [cgal-discuss] Where to start finding Approximate Nearest Neighbor?, Sebastien Loriot (GeometryFactory), 06/23/2010
