- To:
- Subject: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example
- Date: Fri, 25 Jun 2010 04:10:08 -0700 (PDT)
Laurent Saboret-2 wrote:
> Hi,
> Configuring BLAS, LAPACK and TAUCS with cmake-gui is feasible but complex.
> Let's try first an easier solution.
> Please define the environment variables:
> BLAS_LIB_DIR=path to BLAS libraries
> LAPACK_LIB_DIR=path to LAPACK libraries
> TAUCS_INC_DIR=path to TAUCS headers
> TAUCS_LIB_DIR=path to TAUCS libraries
> Then remove CMakeCache.txt and run again CMake in
> examples/Surface_reconstruction_points_3/.
> Regards,
> Laurent S.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Hi,
I tried. It seems to not helping. CGAL still cannot find the 3 libs
automatically.
I'm thinking if I installed the libs correctly.
I downloaded the taucs hover CGAL:
http://www.cgal.org/cgi-bin/cgal_download.pl
And then installed the taucs with g77, although g77 not supported by Lucid
any more. And I thought, the BLAS and LAPACK will be installed, too.
Afterwards, because I was not sure if I installed BLAS and LAPACK correctly,
I installed them through apt-get again.
Could that be the problem?
I saw, there's another download on CGAL which contains taucs_external_src.
Should I install these?
Best regards
Xie Yi
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Re-Error-by-compiling-poisson-reconstruction-example-tp2268101p2268291.html
- [cgal-discuss] Error by compiling poisson_reconstruction_example, Xie Yi, 06/24/2010
- Re: [cgal-discuss] Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/25/2010
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Xie Yi, 06/25/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/25/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Rineau (GeometryFactory), 06/25/2010
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Xie Yi, 06/28/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/29/2010
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Xie Yi, 06/29/2010
