[cgal-discuss] Mismatches between CGAL 3.6-1~squeeze1 and boost 1.40.0-4ubuntu4
- To:
- Subject: [cgal-discuss] Mismatches between CGAL 3.6-1~squeeze1 and boost 1.40.0-4ubuntu4
- Date: Mon, 28 Jun 2010 13:55:04 +0300
Hi!
1) In /usr/include/CGAL/boost/graph/named_function_params.h is defined
template <typename Visitor>
cgal_bgl_named_params<Visitor, boost::graph_visitor_t>
visitor(const Visitor& p)
typedef cgal_bgl_named_params<Visitor, boost::graph_visitor_t> Params;
return Params(p);
which is also defined in
/usr/include/boost/graph/named_function_params.hpp:157
Error is raised when CGAL::mst_orient_normals() is called.
This happens with 3.5.1-1 also. Easy to 'fix' with #if 0 .. #endif in
2) Boost parametrization fails
/usr/include/boost/parameter/aux_/overloads.hpp:81: error: no matching
function
for call to boost::parameter::aux::arg_list<...>::arg_list(...)
The only candidate is
/usr/include/boost/parameter/aux_/arg_list.hpp:214: note: candidates are:
boost::parameter::aux::arg_list<TaggedArg, Next>::arg_list(TaggedArg, const
Next&)
Problem is raised with call to CGAL::make_mesh_3<C3t3>( domain, criteria ).
Won't get fixed with call to CGAL::make_mesh_3_impl<C3t3>( c3t3, domain,
criteria, exude(), perturb(), no_odt(), no_lloyd() );
Lehtonen, Matti
Researcher, head programmer - Helsinki Institute for Information Technology
HIIT
http://www.hiit.fi/
Life is complex. It has real and imaginary parts.
- [cgal-discuss] Mismatches between CGAL 3.6-1~squeeze1 and boost 1.40.0-4ubuntu4, Lehtonen, Matti/HIIT, 06/28/2010
- Re: [cgal-discuss] Mismatches between CGAL 3.6-1~squeeze1 and boost 1.40.0-4ubuntu4, Andreas Fabri, 06/28/2010
- Re: [cgal-discuss] Mismatches between CGAL 3.6-1~squeeze1 and boost 1.40.0-4ubuntu4, Lehtonen, Matti/HIIT, 06/29/2010
