cgal-discuss - [cgal-discuss] Re: Combining two Polyhedron meshes
  • To:
  • Subject: [cgal-discuss] Re: Combining two Polyhedron meshes
  • Date: Wed, 30 Jun 2010 19:20:39 -0700 (PDT)
I'll clarify the question.
I'm trying to implement the Column Modelling algorithm described in this
paper:
http://www.viz.tamu.edu/faculty/ergun/research/topology/papers/bridges05.pdf
In order to do so, I need to create multiple convex hulls and bridge them
with additional facets. Is it possible to either use CGAL::convex_hull_3 in
such a way that it modifies a mesh instead of replacing it, or to combine
several meshes without manually rebuilding them face by face?
I'd really appreciate any insight you guys can offer.
ryan
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Combining-two-Polyhedron-meshes-tp2269159p2274540.html
  • [cgal-discuss] Re: Combining two Polyhedron meshes, notlion, 07/01/2010
