Re: [cgal-discuss] Re: Open a ".OFF" format with triangulation_3 data structure
- To:
- Subject: Re: [cgal-discuss] Re: Open a ".OFF" format with triangulation_3 data structure
- Date: Thu, 1 Jul 2010 10:53:33 +0200
On Wednesday 30 June 2010 21:54:59 achakik wrote:
> i want to know if i can open a .OFF file format with the triangulation_3, i
> can do it with polygon_3 and i want to know if i can do it with the
> triangulation_3, if not, can i transform the polygon_3 to triangulation_3
> thank you
All you can do with an .OFF file and a 3D triangulation is computing a 3D
triangulation of the vertices of the .OFF file. The faces of the OFF file
will
not be represented in the triangulation. Would it be what you expect?
Laurent Rineau, PhD
- Re: [cgal-discuss] Re: Open a ".OFF" format with triangulation_3 data structure, Laurent Rineau (GeometryFactory), 07/01/2010
- [cgal-discuss] Re: Open a ".OFF" format with triangulation_3 data structure, achakik, 07/01/2010
