Re: [cgal-discuss] Mismatches between CGAL 3.6-1~squeeze1 and boost 1.40.0-4ubuntu4
- To: , Stephane Tayeb <>
- Cc:
- Subject: Re: [cgal-discuss] Mismatches between CGAL 3.6-1~squeeze1 and boost 1.40.0-4ubuntu4
- Date: Wed, 07 Jul 2010 15:53:23 +0300
Hi!
If I compile with CGAL 3.5.1, my code compiles nicely.
g++ -c -o triangulator.o -Wall -Wcast-align -Wconversion -Wpointer-arith
-Wwrite-strings -O0 -g -frounding-math -Wno-deprecated -Woverloaded-virtual
-Wextra -ansi -DDEBUG_MODE -DLINUX -I. -I../../libs/libmlomagml/
-I../../libs/libpvsgen/ -I../../../common/liboma triangulator.cpp
The compiler's version is "g++ (Ubuntu 4.4.3-4ubuntu5) 4.4.3".
I will install 3.6.1 as local version (again). then try to compile
"example/Mesh_3".
Lehtonen, Matti
Quoting Stephane Tayeb
> Hi,
> Do the examples of folder example/Mesh_3 compile correctly ?
> Can you give us more details about your configuration (compiler version
> and compiler flags) please ?
> Best,
> Stéphane.
> Lehtonen, Matti/HIIT wrote:
> > Hi!
> > I forced debian Sid Boost 1.42 packages to my ubuntu desktop, but still
> > the
> same
> > error happens... :(
> > Lehtonen, Matti
> > Quoting "Lehtonen, Matti/HIIT"
> >> Hi!
> >> I have now tried this with 3.6.1 and it is still not compiling correctly,
> >> even
> >> thought 3.6.1 release announce claimed
> >> " - Fix compilation errors with recent Boost versions (since 1.40)."
> >> SNIP
> >> Could situation be such that this error is Boost 1.40.0 specific ...
> >> Lehtonen, Matti
> > Researcher, head programmer - Helsinki Institute for Information
> > Technology
> HIIT
> > http://www.hiit.fi/
> Stephane Tayeb
> Software engineer - INRIA Sophia Antipolis
> Geometrica Project-Team
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Researcher, head programmer - Helsinki Institute for Information Technology
HIIT
http://www.hiit.fi/
Life is complex. It has real and imaginary parts.
- Re: [cgal-discuss] Mismatches between CGAL 3.6-1~squeeze1 and boost 1.40.0-4ubuntu4, Lehtonen, Matti/HIIT, 07/07/2010
- Re: [cgal-discuss] Mismatches between CGAL 3.6-1~squeeze1 and boost 1.40.0-4ubuntu4, Stephane Tayeb, 07/07/2010
