- To:
- Subject: Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3
- Date: Thu, 8 Jul 2010 09:58:33 +0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=bjmaioudjEsNtvNf9uduykUMXlfYQu1mnp/6LJpQdHM6PBeZaOY69uqUQOGxlqZ6DY MFNmY3t1cQ4uyCR+kVmkoY6FVkHe538kdBN7bi9zIhAfDVPp4hCQJOfRkbySTg6cxhtE 1z55Wht+b8/mkWJ53P72Yx7cdXFGsKV9qx6uQ=
simply if you want to use it as usual to extend a kernel by adding plane support , you will lack all additional things the kernel provides
the way for this to go (done in other traits , every where in cgal ) is to inherit from specializing kernel , thus you have your kernel with additional support of plane
Regards,
Mohamed Yousef
Regards,
Mohamed Yousef
On 8 July 2010 08:52, Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com> wrote:
Reading the documentation I see no reason why it should.Mohamed Yousef wrote:
Hello,
i think the class "Polyhedron_traits_with_normals_3" should inherit from Kernel_
Thanks,
The concept PolyhedronTraits_3 is quite simple and
Polyhedron_traits_with_normals_3 seems to be a model of it.
What leads you to think there is a bug?
S.
- [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Mohamed Yousef, 07/07/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Sebastien Loriot (GeometryFactory), 07/08/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Mohamed Yousef, 07/08/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Mohamed Yousef, 07/13/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Sebastien Loriot (GeometryFactory), 07/13/2010
