- To:
- Subject: Re: [cgal-discuss] Problem with storing handles as member objects
- Date: Thu, 8 Jul 2010 11:21:27 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=JjJQz3ANV9YJ/Fzq63Xr4ZjcunFs0AlNF7f/wFxN3Icu5khNhs3Tlo7y4vw+oWkniR VinUVPQ5Hp0GHXYROe8cIWJR8iy2VX5CO7pHjrxV0UZ073n0Uo54j0GCgUddfDgqRpTT WlhYyk4StY3EunPyLGdG4tPO+XvUV1sL6vMC0=
I just found the mistake, a really stupid one: I was passing the polyhedron object through the function not as "Polyhedron &plh" but as "Polyhedron plh" and after subsequent calls the handles were just pointing somewhere in the containers of a Polyhedron object that died after the end of the function scope.
Thanks for insisting that the error had to do with some copy/initialization issue. If it was not for that I would just think that there was an inherent problem with the Handle concept.
thanks!
On Thu, Jul 8, 2010 at 8:04 AM, Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com> wrote:
Hello,
I could no reproduce the error you describe with the following code:
#include <CGAL/Delaunay_triangulation_3.h>
#include <CGAL/Simple_cartesian.h>
typedef CGAL::Simple_cartesian<double> Kernel;
typedef CGAL::Delaunay_triangulation_3<Kernel> T;
class Myclass {
private:
T::Vertex_handle _h;
public:
void set_handle( T::Vertex_handle &h)
{ _h = h;}
T::Vertex_handlevoid A( Myclass &mc,T::Vertex_handle hndl)
get_handle(void)
{ return _h;}
mc.set_handle(hndl);
T::Vertex_handle hndl2 = mc.get_handle();
std::cout << &(*hndl2) << std::endl;
void B( Myclass &mc)
T::Vertex_handle hndl3 = mc.get_handle();
std::cout << &(*hndl3) << std::endl;
int main()
Myclass mc;
T t;
t.insert(Kernel::Point_3(1,2,3));
t.insert(Kernel::Point_3(3,2,3));
t.insert(Kernel::Point_3(1,2,4));
t.insert(Kernel::Point_3(2,2,3));
T::Vertex_handle v=t.insert(Kernel::Point_3(24,12,3));
A(mc,v);
B(mc);
return 0;
I think this should be a problem of copy/initialization somewhere in your code. A handle is an iterator over the compact container so there
should be no problem to make a copy.
S.
Costas Tsirogiannis wrote:
I checked if there is any member object that is not assigned properly but there is no issue there.
Here's where I think the problem is:
Assume that you have class that stores a member handle
class Myclass {
private:
Kind_of_handle _h;
public:
void set_handle( Kind_of_handle &h)
{ _h = h;}
Kind_of_handle
get_handle(void)
{ return _h;}
* Assume you have two subsequent calls of some functions A() , B() :
int main(){
Myclass mc;
A(mc);
B(mc);
return 0;
void A( Myclass &c)
Kind_of_handle hndl;
Kind_of_handle hndl2 = mc.get_handle();
std::cout << hndl2->info() << std::endl;
void B( Myclass &c)
Kind_of_handle hndl3 = mc.get_handle();
std::cout << hndl3->info() << std::endl;
What happens to me is that the std::cout in function A works fine
while the std::cout in function B returns a segmentation fault.
It seems that copying a handle h1 to another handle h2 is ok
until the scope of h1 is over. After that h2 is not reliable.
Does this make sense? If yes, how do I go around it?
Whether these handles are stored in objects or not does not seem
to be an issue that creates this error.
thanks
Constantinos
On Tue, Jul 6, 2010 at 11:05 PM, Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>> wrote:
I have not defined a copy constructor for the augmented
half-edges, would that change something here?
So no, the default should be fine.
On Tue, Jul 6, 2010 at 3:31 PM, Sebastien Loriot
(GeometryFactory) <sloriot.ml <http://sloriot.ml><http://sloriot.ml>@gmail.com <http://gmail.com>
Did you define a copy constructor and forget to copy the object?
I think in your case, you should use a boost::Variant as the
number of
possible types is only 2.
Here's scraps of code that are indicative of the situation:
* In the augmented halfedge class I store a CGAL::Object that
contains
* a handle, it could be either a face handle or an edge
stored
in it:
Object _corresponding_triangulation_object;
* And the member functions that make use of it are:
bool overlaps_with_triangulation_edge(void)
{ bool temp = _corresponding_triangulation_object.template
is<Triangulation_face_handle>();
return !temp; }
void set_corresponding_triangulation_object( Object &obj )
{ _corresponding_triangulation_object = obj; }
template< typename Triangulation_item >
Triangulation_item
&t_item )
Construct_object()(t_item); }
Object& corresponding_triangulation_object(void)
{ return _corresponding_triangulation_object; } * So let's say that at some point some function "A" is
called
where it does this:
Halfedge_handle current_ph;
**** do something with current_ph ****
Halfedge_handle target_ph, old_ph;
target_ph = fnwk.surface_polyhedron().split_edge(
current_ph );
target_ph->vertex()->point() = p;
old_ph = target_ph->next();
target_ph->set_corresponding_triangulation_object(current_ph->corresponding_triangulation_object());
CGAL_assertion(target_ph->overlaps_with_triangulation_edge());
target_ph->opposite()->set_corresponding_triangulation_object(current_ph->opposite()->corresponding_triangulation_object());
CGAL_assertion(target_ph->opposite()->overlaps_with_triangulation_edge());
old_ph->opposite()->set_corresponding_triangulation_object(current_ph->opposite()->corresponding_triangulation_object());
* Up to here everything is executed ok. But in the following
code, after the execution
*of "A" is done, when I traverse the polyhedron face that
contains the above halfedges I get *segmentation faults
either
in the std::cout line or in the line where
*->overlaps_with_triangulation_edge() is called.
Halfedge_handle other_ph = ..... ;
Triangulation_edge entry_te = ..... ;
Triangulation_edge current_te = entry_te;
while( !(other_ph->overlaps_with_triangulation_edge()) ||
current_te == entry_te )
std::cout << " other_ph->vertex : "<<
other_ph->vertex()->point() << std::endl;
other_ph = other_ph->next();
if(other_ph->overlaps_with_triangulation_edge())
CGAL::assign(current_te,
other_ph->corresponding_triangulation_object() );
I think there is no problem with accessing the vertex point,
the memory error
has to do with the triangulation handles stored as objects in
the halfedges.
thanks
Constantinos
On Tue, Jul 6, 2010 at 7:48 AM, Sebastien Loriot
<http://sloriot.ml>
<http://gmail.com>
Greetings,
I have a problem with run-time errors coming from an
unorthodox
use of handles:
I make use of a triangulation and of an augmented
polyhedron_3
object. This augmented polyhedron
is a refinement of the surface represented by the
triangulation
: as some algorithm goes on, new edges
are added on what used to be the triangular faces.
It is
important that the halfedges,faces and vertices
on the polyhedron that originate from features of the
triangulation should point to the corresponding
triangulation
features. Thus each feature stores a handle of
the original
triangulation object: a polyhedron vertex stores a
handle
to the original triangulation vertex of the same
coordinates, a
halfedge stores a handle to the triangulation edge or
face on which it lies etc.
When a feature is refined eg a halfedge is split,
these
stored
handles of triangulation features are copied to
the newly created features. And then segmentation
faults
appear.
What do you use to split halfedges ? (the underlying
question
being how
your handles are set)
Specifically, things go wrong when there is an attempt
to access the handle member object of the new feature
outside of
the function that created the feature (and copied the
handle object to it). Any ideas for what could
fix this?
thanks
Constantinos
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] Problem with storing handles as member objects, Costas Tsirogiannis, 07/05/2010
- Re: [cgal-discuss] Problem with storing handles as member objects, Sebastien Loriot (GeometryFactory), 07/06/2010
- Re: [cgal-discuss] Problem with storing handles as member objects, Costas Tsirogiannis, 07/06/2010
- Re: [cgal-discuss] Problem with storing handles as member objects, Costas Tsirogiannis, 07/07/2010
- Re: [cgal-discuss] Problem with storing handles as member objects, Sebastien Loriot (GeometryFactory), 07/08/2010
- Re: [cgal-discuss] Problem with storing handles as member objects, Costas Tsirogiannis, 07/08/2010
